05-30-2020, 08:57 PM | #29 |
Mighty Mouse Wild here. Very nicely built can and great customer service.
05-30-2020, 10:00 PM | #30 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
If you decide to get a can, be careful on the install. The pipe that you connect the hose to that is on the side of the intake manifold is plastic and will bread off from the manifold if you put too much pressure on it from the side. A few members have reported having that problem.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
05-30-2020, 11:54 PM | #31 |
Drives: 2020 LT1 Join Date: May 2020
Can someone explain to me what makes the more expensive cans better than something like whats in the picture I posted?
Not poopooing the expensive ones, I genuinely would like to know what sets them apart before making a purchase. |
05-31-2020, 12:07 AM | #32 |
I bought a couple of the “cheap” ones from amazon. The cans themselves are decent quality and would likely work fine. The biggest difference is the hoses and hardware used to attach the can to the PCV system. The hoses for instance are shaped to be a direct fit and the mounting brackets are specifically made for the car in which it’s being installed. Also, they use factory quick connects avoiding the use of hose clamps. Other than that, there’s probably little difference.
06-01-2020, 12:03 AM | #33 |
Drives: 2018 Summit White 1LE Join Date: Oct 2019
EE dual port
Question on Catch cans...
If they need vacuum to work and they don't function at wide open throttle, wouldn't it be better to buy a catch can like a dual port Elite Engineering that also pull vacuum from in front of the Throttle body so it would function all the time? Thanks! |
06-01-2020, 06:54 AM | #34 | |
2017 Camaro SS 1LE
Pray ported TB/IM TSP 1 7/8 Long tube headers w catted con pipes Taylor plug wires Mishimoto oil cooler Elite X2 catch can |
Thread Tools | |
