05-29-2020, 05:12 PM | #1 |
6.2L engine?
Is the 6.2L engine in the Camaro the same as the 6.2L engine in the Siverado pickups?
05-29-2020, 05:42 PM | #2 |
Drives: 2017 Camaro 1SS, 2023 Sierra Join Date: Feb 2014
Basically, but with some different internals, compression ratio and tune, I think.
05-29-2020, 07:20 PM | #3 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
2020 Silverado Type: 6.2L V-8 VVT DI with Dynamic Fuel Management and Stop/Start Bore & Stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Block material: Cast aluminum Cylinder Head Material: Cast aluminum Valvetrain: Overhead valve, two valves per cylinder, variable valve timing Fuel Delivery: Direct high-pressure fuel injection with Dynamic Fuel Management Horsepower (hp / kW @ rpm): 420 / 313 @ 5600 (SAE certified) Torque (lb.-ft. / Nm @ rpm): 460 / 623 @ 4100 (SAE certified) 2020 Camaro Type: 6.2L LT1 V-8, VVT with Direct Injection (cylinder deactivation with automatic transmission) Bore & stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Block material: Cast aluminum Cylinder head material: Cast aluminum Valvetrain: Overhead-valve, two valves per cylinder Fuel delivery: Direct, high-pressure fuel injection Horsepower (hp / kW @ rpm): 455 / 339 @ 6000 (SAE certified) Torque (lb.-ft. / Nm @ rpm): 455 / 614 @ 4400 (SAE certified)
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
05-29-2020, 08:26 PM | #4 |
Drives: SS 6 speed of course Join Date: Jan 2016
Different intake and exhaust manifolds
05-29-2020, 08:38 PM | #5 |
Yes of course but he was just asking about the engine. Might as well throw in the rear end, fuel system, injectors etc.
05-29-2020, 10:39 PM | #6 |
um dude the intake and exhaust manifolds are part of the engine.
05-30-2020, 01:38 AM | #7 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I think it would be closer to a C7 Corvette engine, which shares the same name. The base Stingray makes the same amount of power and 5 lb-ft more of peak torque.
But even then, they have differences such as different exhaust manifold, where the C7 has a basic 4-to-1 collector while Camaro has a tri-Y design, probably for better scavenging. According to GM, 20 percent of the components of the Camaro LT1 is specific to it. https://media.gm.com/media/us/en/gm/...wertrains.html
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
05-31-2020, 01:23 AM | #8 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I am assuming the Corvette exhaust manifold didn't fit the Camaro for whatever reason, which gave the design team an excuse to completely redesign a new header for the Camaro. It seems like they had to have had a good reason to create a one off unique header? What does the 6.2 truck header look like?
I'm not sure if gm releases the hp and torque plots anymore but I have seen one for the LT4 somewhere. Since apparently the Camaro headers don't change the output at all, since the claim is that the extra 5hp and 5lb ft of torque on the Corvette come from the Corvette NPP. I believe the Camaro LT1 has ULEV status so not sure if the Corvette, so maybe this is the justification for a one-off Camaro header? |
05-31-2020, 07:47 AM | #9 | |
Drives: 2018 1SS M6 Join Date: Nov 2014
Trucks are designed to serve a different purpose, torque is king over actual power output for towing. |
05-31-2020, 09:08 AM | #10 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'm sure the exhaust manifolds are different due to packaging issues.
Baby Blue
05-31-2020, 12:02 PM | #11 | |
Drives: 2019 ZL-1 Join Date: Feb 2009
As 6spd said the shortblock are the same. The intake manifolds are longer runners and have a higher profile in height- more torque. The Camaro exhaust headers are unique. So they have the same cam, compression ratio, heads. The tune is different which affects VVT timing etc. 6.2L L86 TECH SPECS Type: 6.2L Gen V V-8 Small-Block Displacement: 6162 cc Engine Orientation: Longitudinal Compression Ratio: 11.5:1 Valve Configuration: Overhead valves Valves per Cylinder: 2 Assembly Sites: Tonawanda, NY and St. Catharines, Ontario Valve Lifters: Hydraulic roller Firing Order: 1 – 8 – 7 – 2 – 6 – 5 – 4 – 3 Bore x Stroke: 103.25 x 92 mm Fuel System: DI Fuel Type: Premium recommended Maximum Engine Speed: 6000 rpm Emissions Controls: Catalytic converter, three-way catalyst, positive crankcase ventilation Horsepower: 420 hp (313 kW) @ 5600 rpm* Torque: 460 lb-ft (624 Nm) @ 4100 rpm* Block: Cast aluminum Cylinder Head: Cast aluminum Intake Manifold: Composite Exhaust Manifold: Cast nodular iron Main Bearing Caps: Cast nodular Crankshaft: Forged steel Camshaft: Billet steel Connecting Rods: Forged powder metal
2012 Yukon XL Denali w/ 6.2 AWD |
05-31-2020, 12:20 PM | #12 | ||
Side note, From what I have seen I doubt there is much difference between the Vette manifolds and Camaro Tri-y for power because the exit side of the Vette manifolds are a bit larger then the Camaro's headers. Then GM neutered the Camaro Headers further with the Cat pipes that neck down under 2" before the cats. With the cat pipes deleted they likely are very close maybe a slight edge to the Camaro.
2016 NFG 1SS A8
06-01-2020, 10:08 AM | #13 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
As I own both vehicles in question and as said, the main engine is the same on the truck L86 6.2 to the Camaro SS LT1 6.2.
The intake manifold is different, the HPFP and injectors are different, and the exhaust manifolds are different. The tune is changed as well in order to try and move the torque down lower where the trucks need it for towing.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
06-01-2020, 10:32 AM | #14 |
Then I don't know why they did the tri-Y design. Packaging makes sense, but IMO tri-Y is probably more expensive to make than a 4-to-1 exhaust manifold.
And well, they have to cap the Camaro power to be slightly less than the Corvette because Corvette. It's just not as bad as it was in the past. Sent from toaster or something
Current:
