02-05-2020, 07:30 PM | #15 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
I am going to go with the 67 XT 2 peice ramps. I will just use a peice of wood to raise up.the front just enough to not rub
02-05-2020, 10:34 PM | #16 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
56" 2-piece here, no issues.
02-08-2020, 06:53 PM | #17 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I love my race ramps. I believe mine are the 67 inchers. I got the tallest ones possible.
why not? i'd rather have too much room under there than not enough
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
02-08-2020, 08:54 PM | #18 |
Roger that.. I ordered my 67in 10in lift race ramps to days ago. Figured more the better. I would kick myself in the ass if I got the 8in 56long and wanted morr
04-01-2020, 01:25 PM | #19 |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
Want to order a set of 80 inch ramps. Owned a shorter set previously when I owned Corvettes and always wished they were a little taller. The 80's are 10 inches tall instead of 8 inches.
Seems like the price of these is set in stone. Any suggestions on how to find a lower selling price? Best price I have found is $420. Thanks
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
04-01-2020, 07:36 PM | #20 |
I would get the 80" if I had to do it all over again. I have the 67xt with the 10" lift height for $363 My zl1 will not drive up on the ramps. Now I have to either buy the extenders for another $127 or Jerry rig some kind of wood ramp set up to help with the approach angle. So $490 to have the 67xt with the extenders vs the 80" for $420.
04-02-2020, 02:12 PM | #21 |
I ordered a set of the 80's. Called Race Ramp and they were more expensive than Amazon so just ordered them from Amazon.
04-02-2020, 02:25 PM | #22 |
Drives: 18 ZL1 mostly stock Join Date: Jan 2020
I have the 80's and think they are the perfect ones for the Zl1.
07 LMB Z06 Cartek 4x heads and cam, ARH, Vararam, FAST 102, NW 102
18 ZL1 M6 MTI cam, FED heads, FBO's |
04-02-2020, 02:58 PM | #23 |
Yeah good choice with the 80in. I definitely wanted 10" lift. But I didn't want to have something that long at first but now I have to buy the extenders. Oh well it will work.but cost me a few extra bucks.
Not sure how some peeps have them and use them without rubbing. |
04-03-2020, 10:10 AM | #24 |
Drives: 2019 ZL1 Camaro Join Date: Oct 2016
Hi,
Is this the 80 inch version that you guys are using? It has an 8.5 degree approach angle. Just want to confirm that this is the Race Ramp model that works. Thanks, Tyrolblue67 |
04-03-2020, 07:27 PM | #25 |
My 67xt don't work on level ground maybe with an incline it would work. Hope I could try tomorrow if weather is nice
04-03-2020, 08:01 PM | #26 |
Drives: 2017 ZL1 Join Date: Jan 2017
I have the 56", 8" tall, single piece ones and they just fit on flat ground approach angle wise.
04-03-2020, 08:12 PM | #27 |
When I slid the 67xt under the front they were quite a bit off of the tires and touching the splitter. On a level garage floor. Not sure how much it would take to clear. Gonna try a 3/4 plywood first before I go drop 130 on the extenders.
That is the same approach angle as those 56 with the 8in lift. |
04-05-2020, 03:12 PM | #28 |
Plywood worked perfectly. In case anyone out there cares. Cut it just as wide as the ramps and about 12in long. Lined it all up to the tire and drove right up no problem. Saved me some coin. Plywood I had just kicking around the house.
