07-30-2019, 08:38 AM | #15 | |
Drives: A few Join Date: Oct 2017
It's pretty easy to find loaded crew cab 1500s with the top motor, tow packages, etc with 1,200-1,300lb payloads. If you put 500lbs in the truck then you can tow ~7,000lbs with one of those "12k max tow rating" trucks. Really GRAWR matters most but few people are going to cat scales with a 1500 and an open trailer ha OP: Get the trailer with the widest width fender to fender that you can find that meets your quality/price standards. These cars are wide. My SS 1LE barely fits on my Featherlite and the ZL1 1LE is even worse. The featherlite 3182 is a narrow 79". And 81-83" width between fenders would be a much more comfortable loading/unloading experience.......
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
07-30-2019, 08:39 AM | #16 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Never seen or heard of this double dolly method. Googled and found no pics do you have any and how exactly do you get the car on? Do you basically build your own trailer by connecting the two dollies?
07-30-2019, 08:41 AM | #17 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
That being said, You guys can do whatever you want. I'd just hate to see a "Wrecked my truck, my trailer, AND my Camaro today going to the track" thread. |
07-30-2019, 08:43 AM | #18 |
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Trailer
I'll sell you this trailer as I never use it anymore
07-30-2019, 08:48 AM | #19 |
I think he meant two wheel dolly.
-Dave
07-30-2019, 08:59 AM | #20 |
Drives: Colorado ZR2 (2.8 DIESEL) Camaro SS Join Date: Jun 2019
I have a colorado with diesel and it has a tow rating of 7700. I tow all kinds of crap with it. Canam X-3 weighs about 1500 plus trailer weighing about 1500 total 3000 tows fine. I could probably fit my car on my trailer but it only has a rating of 3500 so i would probably be a bit over the rating.
I think u-Haul is just being safe with there rating numbers as ive seen someone on this forums with a colorado and a camaro on a trailer and there towing it. |
08-22-2019, 11:37 PM | #21 | |
08-23-2019, 12:07 AM | #22 |
Drives: 2016 SS Convertible Join Date: Sep 2016
I towed a 3600lb BMW 525i with a Colorado using a Uhaul trailer.
Put on the website what I was towing and it let me rent it. My truck is rated to tow 7K lbs. the uhaul car hauler is not too heavy - under 2K lbs. so I was right about 6K including cargo. Towed it 300 miles. Did great. No issues. The trailers are set up for about 10pct of weight on the hitch. So under 600lbs on the hitch also within the ratings. But that’s about the max I would tow with that truck. Used to use a 2500 burb with 8.1 when I was racing and towing all the time. That sucker was a beast. Could barely tell a trailer was back there. Barely reduced the MPG too. Ha. The colo got about 12 towing. Still better than the burb unloaded. Ha |
08-23-2019, 08:02 AM | #23 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Apparently you haven't seen the 1500's they have been making over the last 5years?????? Considering you have a 20 year old F-150 you are correct i'm surprised that thing can even pull it's own self down the road, most 1500's built in this decade are rated at 10K+ for towing.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap Last edited by ICTsccaCamaro; 08-23-2019 at 08:40 AM. |
08-23-2019, 08:15 AM | #24 |
ITCRNRS
I'm running a 18ft steel deck with etrack, even with my "little" 1500 I can set the cruise at 85mph with no issue. This set up has towed thousands of miles with no issue.
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
08-23-2019, 08:30 AM | #25 | |
Drives: 2019 ZL1 1LE Camaro A10 Join Date: Jun 2019
2019 ZL1 1LE
2016 Mustang GT 2014 GT 500 2012 GT 500 2010 Mustang Spec Iron 2003 New Edge w/Coyote Now running in America Iron 2000 New Edge w/ Coyote 2004 Corvette 2002 Corvette |
08-23-2019, 09:57 AM | #26 | |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
For these knuckleheads that say you should not haul a 4000 lb camaro on a 2000lb trailer with a 1500 pickup.
Check this out
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
08-23-2019, 10:30 AM | #27 |
Ya - the Colorado is more capable than 1/2 tons from 10 years ago, and about the same size for that matter. The new 1500's are as big and more capable than 2500's from 10 years ago.
And I've logged a ton of miles towing race car trailers (open) with everything from 90's Dodge Durango's to 1500 and 2500 Suburbans, the nissan full size (Titan and Armada), 2000 era 2500 HD silverados and the latest Colorado. One thing I can say with confidence - what the MFG's use as their tow ratings, GVWR and tongue load limits are pretty much spot on. 90's era 1500 burbs were rated to tow about 5500-6000 lbs depending on the model and that was truly what they could handle. Even the 2000 era 2500HD silverados were only rated to around 10Klbs which is about where the current crop of 1500 pickups come in. That is complete overkill for a 5500lb car trailer set-up. And there is certainly no need to go up to the current crop of 2500 or 3500 trucks - those are really needed these days only if you have a 5th wheel or a super huge enclosed trailer maybe - especially if you tow a lot and diesel is going to be a better choice for mpg and torque curve. 5500lb car trailer isn't that much of a load IMHO. |
08-23-2019, 10:49 AM | #28 | |
Drives: White 2015 Z/28 Join Date: Jul 2017
Do I recommend it? No! It was hell on the truck, but it still did it safely, which is all that matters to me. |
