09-10-2020, 09:31 AM | #183 | |
Drives: 2016 2ss, E85, tune, intake Join Date: Aug 2020
2016 2SS, A8, cat delete, DSX E85 kit, CAI, tuned, Velgens.
1949 F-1. Camaro frame on full coil overs, CCWs, cammed LS, built 80, yada yada |
09-11-2020, 01:47 PM | #184 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Guys, I'm going to be installing my LT2 manifold this weekend and i have a couple of noob questions as this is my first time doing something like this. I'm going to be following the msd intake directions as I'm sure the process will be the same.
1) Do I have to use loctite on the manifold bolts? 2) Do I actually have to grease the openings on the brake booster line and Map sensor like MSD says too? if so, what is this Grease called that goes on those locations? Seems odd to me to grease those. 3)Is the torque sequence for the LT2 the same as the MSD intake (MSD provided a chart where as there are no directions for the LT1 or LT2 intake (I know the inch lbs to torque it too) 4) There is a step in the MSD directions where it tells you to use rubber bands to hold the back two manifold bolts when removing the stock manifold. I have no idea why it is telling us this and what it means? Could someone please explain? Here is the link to the MSD directions. https://static.summitracing.com/glob...s/msd-2700.pdf Step 5 is the rubber band part. From what i understand the bolts won't fall out because they'll be held up by the intake? Thanks for the help. |
09-11-2020, 02:10 PM | #185 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
See my answers in bold.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
09-11-2020, 07:49 PM | #186 |
Drives: 2016 2SS 8AT Join Date: May 2018
The rubber bands help. They hold the bolts up so you can pull the intake out and not have the bolts scratch or hang up in the ports. You don't need them but trust me it helps
09-12-2020, 04:03 PM | #187 | |
According to this article the LT1 average runner length works out to 207.5 Amazing how long the runner is on the LT2 and still carries power well up top, but also makes sense how much power it has down low. Also can’t believe the msd has that little plenum volume, it seems much larger than the LT1. I will say the Lt1 utilizes the space in above the valley cover well, even more efficiently than the lt2
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 09-12-2020 at 05:41 PM. |
09-12-2020, 05:40 PM | #188 |
Thanks for your help with my questions guys. Unfortunately my car just had the hot start issue so I'm going to leave the manifold off for now while I try to get GM to believe it happened to me so they replace my starter. Hoping this is covered under the power train warranty.
09-12-2020, 05:49 PM | #189 | |
09-12-2020, 06:08 PM | #190 |
Thanks I'll try that next time. I barely put my car in situations where I "hot start" it so it may be awhile. This was the first time, after a one hour drive where during the last 10 minutes I drove hard for 2 of the minutes due to twisty roads, pulled up to a car wash just to rinse crap off my car. After 5 or 6 minutes I went to turn it on and it did the super slow cranks before it started. Seems like power train does not cover starter. Now I'm trying to see labor cost replacement for it as the part is pretty cheap at least.
09-12-2020, 06:36 PM | #191 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 09-13-2020 at 06:57 AM. |
09-13-2020, 09:49 PM | #192 |
I ended up just adding the 3L to the original manifold volume so I’m running 16,420cm^3 and is looking ok. The transients are looking pretty good. Fuel comes right in and levels off. I am thinking the 1.27 multiplier was a bit too much and made it feel a little more lazy on the hit, but the data looked good. I ended up dropping it to the 16,420 we’ll see how I like it.. If anyone tries it let me know if you notice anything.
Also, my throttle was closing over 6,000 incrementally toward 6,800. I must’ve had my tune torque values set right up to the limit for the old combo, but I worked that all out, and it’s open to 6,800rpm. Yeah it’s pulling hard up top now
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 09-14-2020 at 07:14 PM. |
09-14-2020, 12:27 PM | #193 |
Drives: 2017 Camaro SS, 2017 2500HD, 2014 H Join Date: Jun 2020
Got my manifold from GPI and it looks fine. Went with the modified to fit but unported.
Question...has anyone considered replacing the vac. hose barb up front? Sticks up like a flag pole or something! Lol! Or is it not that noticeable when installed? |
09-14-2020, 03:10 PM | #194 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
How long did it take to get the Manifold from GPI? ordered one last week same as you did, unported modified.
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
09-14-2020, 03:55 PM | #195 |
Drives: 2018 Camaro SS/1LE Join Date: Jan 2018
Yea it Definately sticks upwards.. I used the push connects from the stock hose and put them on a 3/8” hose.. one of the push fittings is a 45 degree. So I used that one on top to help angle it down.. looks good and clears fine.. my bad with the first pic, don’t know how to rotate
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
09-14-2020, 05:31 PM | #196 |
Drives: HyperBlue 2SS 6M NPP MRC Nav Join Date: Dec 2015
I ordered on 8/21. I received an email on Friday that it was in process. Didn't feel like too long of a wait for me.
2016 HyperBlue 2SS 6M NPP MRC Nav
