05-12-2019, 05:46 PM | #1 |
Drives: '19 Camaro 1LE 2.0 Turbo Join Date: Mar 2019
What size tires are SS Camaros in FS running?
I just picked up a 2.0L 1LE and I need a set of autocross wheels and tires for DS.
Since the 2.0L 1LE has the same wheel size as the non-1LE SS (20"x8.5 - Front & 20"x9.5 - Rear) I'm wondering what the SS's running in FS are using. I'm going to guess the hot setup is RE71s on 19" wheels. Just not sure about the width. |
05-13-2019, 12:41 PM | #2 |
Drives: 2017 Hot Red 2ss Auto adrenaline Join Date: Aug 2017
275 front and 285 rear is what you should get on there, some run 265 frnt for better feel but for ultimate grip for the front the car car go 275
05-13-2019, 03:41 PM | #3 |
Drives: 2018 1 SS Join Date: Dec 2018
275 will fit on the stock front rim?
05-14-2019, 06:34 AM | #4 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
For autocross, it's pretty common for people to run tire and wheel combinations that by Tire & Rim Association standards are technically "out of spec".
At least autocross is run under controlled conditions where risks are minimized, not on public streets or with other traffic, and each "drive" is of very short duration. Plus, the max and min recommended wheel width guidelines are not hard pass-fail in nature, though you probably do give up a little from any longer-term safety margin. Norm
'19 WRX 6M (the family sedan . . . seriously) |
05-14-2019, 10:59 AM | #5 |
Drives: 2020 2SS 1LE Join Date: Nov 2017
I run 19" wheels, 265 in front 285 in rear. I don't think you can fit wider on the stock wheel width (which is required for F Street), and even if you could you would probably have a rounded profile that actually reduces your tire patch.
Chevy putting an 8.5" wheel on the front is becoming a disadvantage for us, the latest Mustang GT has a 9" front wheel. |
05-14-2019, 12:51 PM | #6 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
honestly with the lighter weight of the 1LE i would go 265/275. or 275 square.
When I had my FS car i ran 275 square and in the final year i ran 275/285. The turbo has a lot less weight up front, i think the 265 would be perfect balance of grip and turn in.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
05-16-2019, 10:29 AM | #7 |
What is the current Street class rules for wheels when it comes to width...can you run the widest stock wheel available from the manufacturer? Does this include 1lE rims on a SS in FS? Or is it the widest for the model, so SS could not run 1LE wheel dimensions
in FS? |
05-16-2019, 10:36 AM | #8 |
Found it:
13.4 WHEELS Any type wheel may be used provided it complies with the following: A. It is the same width as standard and as installed it does not have an offset more than ±7.00 mm (±0.275”) from a standard wheel for the car. The resultant change in track dimensions is allowed. B. Wheel (rim) diameter may be increased or decreased 1” from the standard part. This change may be applied to the front, rear, or both axles. So based on this I couldn't run a wheel with the same width as a 1LE rim, unless Chevy offered an option to run that width on a standard SS, which I don't believe they do. To run a 1LE wheel I would have to do a model conversion, that would bump me out of FS anyway. Right? |
05-16-2019, 02:48 PM | #9 |
I know neil and Finch really really like the 275 front setup, I drove that car at an event and it was super numb, but the frontend grip was amazing.
05-16-2019, 02:51 PM | #10 | |
05-16-2019, 02:56 PM | #11 | |
ApexIT talks above that he still ran 275s in the front on that width wheel...which I wouldn't have thought possible (or at least would fit so badly that the profile would be too round), but I wouldn't argue with him. I believe him to be the fastest FStreet Camaro driver in the country (even if he abandoned us this season and sold his car) so he knows his stuff. Mike |
05-20-2019, 08:49 AM | #12 |
Thanks for the replies
05-20-2019, 08:50 PM | #13 |
Drives: 2016 1SS - M6 Join Date: Jun 2017
AJD …. welcome aboard.
I might have some used F Stock configuration black CF5V's ForgeStars for sale shortly..... nice shape and not beat up. PM me if you have any interest and I'll keep you posted on my decision …..considering selling the car and dropping the class (16 SS + ice mode = no bueno) |
