05-20-2016, 07:15 AM | #29 |
Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
Has to go on the Corvette first. Right? I mean...it has to....right??? (Sarcasm intended).
05-20-2016, 07:35 AM | #30 |
Drives: 2013 1LE Join Date: Feb 2012
And since they haven't been seen before it isn't possible...
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
05-20-2016, 08:14 AM | #31 | ||
Drives: Car Join Date: Jun 2010
Thus far, it hasn't been bad. The seat bottom started to discolor a little bit, but I wiped it off with some cleaner and it's fine. From what I've seen, it's plastic coated, so it's not as easy to stain. Also, I don't have pets or kids and I'm pretty clean when I get in the car.. So your mileage may vary. |
05-20-2016, 10:18 AM | #32 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
What does a good high performance wheel go for now? I mean the upgrade on the Camaro is $2000.00, so that's $500 each wheel.
I would think for them to be something more mainstream, they will need to get supply chain optimized for say a retail of $800 to $1000? Would some of you spring for a $4K wheel option on a ZL1? I'd consider it, but not at $15K.
05-20-2016, 11:05 AM | #33 | |
Moderator.ca
And I'm pretty sure that any tire that can be fitted on a 19" forged aluminum wheel of a particular width will also fit on the same size carbon wheel.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
05-20-2016, 11:35 AM | #34 |
Moderator.ca
As for the price of carbon fibre dropping due to increased usage ... don't count on it.
The primary reason for just about any technology's price to go down with time is because there is less and less R&D to pay for with something. Once somebody has figured out how to make something the first time, everybody else can just copy it with minimal effort. After that, its largely a matter of refining the processes to make it faster/cheaper/easier. Those refinements take a lot less effort, but they tend to yield only marginal improvements. The thing with carbon fibre is that the stuff is fairly mature already. A lot older than VCRs (or Beta). It was invented in the late 1950s, and became a usable material in the 1960s. Its simply a very expensive material to work with. Both in straight up material cost and manufacturing cost. Producing raw carbon fibre is a fairly complex process to start with, and then to turn it into anything useful typically requires either a lot of human effort or absurdly complex machinery. And when you're done, there is a decent chance that whatever you've made needs to be tossed due to flaws. All the time and effort poured into it is now worth exactly nothing. Can't even melt it down to recover the material cost like you could with steel or aluminum. Will the cost come down? Sure, just not fast enough to make it affordable for the foreseeable future. If after half a century of effort to make it cheaper its still very expensive, what do you think the odds are that its going to come down substantially any time soon? Somebody could have made a radical breakthrough this morning for all I know ... but I wouldn't count on it.
05-20-2016, 02:15 PM | #35 | |
Drives: 1992 Z28 1LE; 2015 Zl1 Join Date: Mar 2009
The two underlined items above are the major areas for savings and they are being realized. The machines are complex, but that complexity is getting more affordable all the time.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x 1991 Camaro Z28- 1991 Camaro Z28 1LE- 1992 Camaro Z28 1LE- 25th anniversary 2015 Camaro ZL1 |
05-20-2016, 02:50 PM | #36 | |
05-20-2016, 02:55 PM | #37 | |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
I hope I'm wrong but there is not that great of a demand to have a low priced CF wheel to justify the expense of R&D and tooling up once a process would be identified because you CAN save that weight - which is nominal in most cases - via other means. Sure, if you're buying a $300K-$500K (or more - as in a Veyron, etc) exotic, what does it matter if you spend another $20K or more in CF wheels? Yes - the GT 350 has them but what do they REALLY add to the car? Even on the C7Z - how many buyers would shell out yet another $10K minimum to get CF? I'm sure they are few and far between. And, whenever the manufacturers DO get a reasonably priced CF wheel developed, there will be a newer, even more expensive (!) wheel that is even lighter yet (made out of some yet to be identified material - Unobtanium?) that the Gotta Have the Most Expensive Wheel Out There crowd will be wanting to buy. It's a never ending circle!
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
05-25-2016, 08:49 AM | #38 |
Drives: 2016 2SS Join Date: Mar 2014
They don't make that big of a difference on the gt350 to gt350r, so why assume they will make a big difference on other cars?
05-25-2016, 08:51 AM | #39 |
I used to be Dragoneye...
? They should make a massive difference. That's a major part of why the R-version can do what it does...
05-25-2016, 08:55 AM | #40 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Less unsprung weight is a big difference
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
05-25-2016, 11:10 AM | #41 |
05-25-2016, 11:23 AM | #42 |
Well you can get the suspension package and I will get the carbon wheels.
