07-11-2021, 03:35 PM | #1 |
Bank 1 & 2 system too lean
Hey guys. I installed the Procharger P1X about two weeks ago and everything has been fine on their remote tune. I installed the MM wild catch can yesterday and woke up today with CEL for lean system on bank 1 & 2. Any ideas?
2017 Camaro 1SS
Procharger P1X Stage 2 intercooler |
07-11-2021, 03:43 PM | #2 |
Sounds like a vacuum leak or improper placement of your catch can hoses...
07-11-2021, 04:09 PM | #3 |
Weird.....I attached the clean side of the can to the procharger manifold going into the intake manifold and the 8AN fitting to the oil filler cap attachment just as the instructions said. Other than capping off the valley that was all that was done. Ran fine for two weeks before the can install so I suspect you are right.
2017 Camaro 1SS
07-11-2021, 05:27 PM | #4 |
I just checked everything and the car seems to be running just fine no rough or high idle. Attempted to clear the code after tightening all hose clamps and such and it still persists. The scanner shows my IAT in red and at 129 when I hook it up to HPtuners scanner. I did notice the hose on the intake port had slid back a bit so I moved it up and tightened the clamp down again....still have CEL.
2017 Camaro 1SS
07-11-2021, 05:54 PM | #5 |
I put the scanner on it again and got the CEL to clear but bank 2 still looks about 4.7 higher thank Bank 1 at idle and seems to stay higher in all rpm ranges....
2017 Camaro 1SS
07-12-2021, 10:17 AM | #6 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
Happened to my Whipple after 20k. It was a leaking actuator diaphragm below the TB.
07-12-2021, 11:01 AM | #7 |
Interesting....I got the code to clear last night and re routed my Catch can hoses so they aren't under the TB or touching anything but the intake tube and can get a bit more airflow. I noticed my IAT jumping into the red at WOT and took Joshinator's advice about improper placement of the hoses. Going to take it to my friend today to have him look at it since bank 2 is consistently higher than bank 1. Right now I'm thinking I may have to order some LT4 injectors and high pressure pump which is something I was going to do anyway just not as soon.
2017 Camaro 1SS
07-12-2021, 07:47 PM | #8 |
Old badass
Gosh, got to thinking I don't even know if a PC has an actuator bypass but Joshinator's comment about vacuum leak I just threw it out there because it probably is a vac leak.
07-12-2021, 09:32 PM | #9 |
I wonder if a check valve in the CC is stuck or not working. Hopefully the hoses were connected up right...? That would do it for sure.
07-12-2021, 11:29 PM | #10 |
After re-routing the hoses last night and driving it to my friend's shop everything is good. My friend looked at the tune and data log I had saved and thought everything looked fine. My IAT is lower today after relocating the smaller hose leading up to the intake manifold. I appreciate the brainstorming here gentlemen! It was likely a vacuum leak that I must have fixed yesterday.
2017 Camaro 1SS
07-13-2021, 08:19 AM | #11 | |
