Old 07-24-2021, 12:54 PM   #57
Flexhorn
Drives: A10 ZL1
I have zero issues of noise with the Toyo’s. It hooked excellent at the track when I first got them. Now, I have 4K miles on them and they spin horribly. I’m at 824Rwhp
Flexhorn is offline   Reply With Quote
Old 07-24-2021, 02:44 PM   #58
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Must be going deaf or wear ear plugs when driving, those things are noisy.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 07-24-2021, 11:03 PM   #59
dbs1
Drives: 2017 ZL1
At 4000 miles ur 75% done. And a measley 824 at the wheels? Can't know why ur spinning...
dbs1 is offline   Reply With Quote
Old 07-25-2021, 07:44 AM   #60
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Ls_Camaro View Post
Looking into a set of these tires for the rear while running a summer performance tire up front like a Continental ECS or Michelin PS4S.
Michelin PS4S is the undisputed champ. Don't get distracted with other tires.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 07-25-2021, 10:55 AM   #61
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
They are good if your car is stock. Once you start adding power forget about it.
An 80 roll i spun like crazy on ps4s, 60 roll I was going sideways, anything lower and I would be wrapped around an object.
Old 07-25-2021, 11:39 AM   #62
JSH
JSH's Avatar
Drives: '20 ZLE
Mine work fine in manual in 3rd from 40mph and up, with a shift to Auto above 5000rpm. They're never good in Auto on a downshift.
'20 ZL1 1LE A10,
Old 07-25-2021, 11:58 AM   #63
Sickspeedkuwait
Sickspeedkuwait's Avatar
Drives: '17 ZL1 M6
This
I do zero WOT pulls below 70mph
'17 ZL1 M6
8xxwhp Magnuson 2650
Sickspeedkuwait is offline   Reply With Quote
Old 07-25-2021, 01:13 PM   #64
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Sickspeedkuwait View Post
This
Take it up to 8000+ DA, it'll be fine.
'20 ZL1 1LE A10,
Old 07-25-2021, 02:17 PM   #65
Sickspeedkuwait
Drives: '17 ZL1 M6
'17 ZL1 M6
Old 07-25-2021, 04:56 PM   #66
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I like my oxygen rich air don’t ruin it .
Old 07-25-2021, 05:19 PM   #67
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
My stock ZLE will spin them at 50mph often and in fourth gear sometimes fifth I feel like the rear is trying to kick out. I’m not very impressed with the dry performance of the Michelin’s to be honest. I honestly expected better and our roads up here right now are warm so the tire has warm temperature in it. I find them to be greasy.
But, they are great for the wear factor and ride and comfort. Can’t have it all unfortunately.
Sorry, I should clarify I’m referring to the Michelin’s PS4S.
Old 07-25-2021, 07:06 PM   #68
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I think your hennessey built ZL1 makes 600rwhp
Old 07-26-2021, 07:41 AM   #69
JSH
JSH's Avatar
Drives: '20 ZLE
Closer to 1000
'20 ZL1 1LE A10,
Old 07-26-2021, 07:48 AM   #70
Closer to 1000
He meant that your car's 1000 rwhp in Sealy (elevation 200 ft) is only 600 rwhp in Denver (elevation 5200 ft)... and we all know how he likes to jest and poke to tease
