Old 02-28-2020, 05:04 PM   #15
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
be carefull dont overtighten em my buddy broke a few of his bolts and had to buy new ones lol sucks for him
Old 02-28-2020, 05:53 PM   #16
6spdhyperblue
Drives: 6th gen
GM has the LT2 out, which may or maynot fit. Beauty is in the eye of the beholder. There are a few sheet metal intakes out, they seem IMO too short in runner length
Look the instructions say to torque the small bolts before the manifold is installed, I don't know why but it is clearly in the instructions. Maybe MSD feels that the two haves need to be joined only after the manifold has kind of taken a set from production. Don't beat me up, I installed the manifold 3 years ago, but again I clearly remember the instructions saying the small bolts needed to be tightened. I clearly remember and then disregarding said instructions as their spec was too much for such small blots. I hand tightend my. Your built in hand wrench maybe um less ideal
Page 5:
https://static.summitracing.com/glob...s/msd-2700.pdf
The intake should not be stored with outer bolts torqued. It will warp the intake!
Once off the heads store as delivered!!
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 07-22-2021, 11:46 AM   #17
Osbornsm
Drives: 2018 SS 1LE
Reminder for those of you out there with MSD.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 07-22-2021, 01:32 PM   #18
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I didn't see it stated if it was new, used or had been ported. Maybe I missed that offering or if someone else asked that question.
Old 07-22-2021, 01:37 PM   #19
laynlo15
laynlo15's Avatar
For sure, don't get confused on torque in inches and ft lbs. I had a guy when I was working tech at Magnuson and he was trying to torque the intake at a 109 lbs of torque when it specifically said in the instructions 109 inch lbs. Broke every bolt that he tried to install. He called me and asked if he'd gotten a bunch of bad bolts and I asked him what he was torqueing the bolts at and he realized before he even answered he screwed up and read the information wrong.
Old 07-22-2021, 06:50 PM   #20
17MaroSS
Drives: 17 2SS 6sp
I read on page 1 someone mentioned that you have to re-buy bolts if you takeoff the manifold. Is this really true?
FOR SALE 17 2SS 6spd h/c/i/fbo
17MaroSS is offline   Reply With Quote
Old 07-22-2021, 08:47 PM   #21
s346k
s346k's Avatar
Drives: like an old lady
no. i've had mine off and on several times with the same bolts. also had it apart a few times and reused the bolts.
Old 07-22-2021, 09:09 PM   #22
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
When I installed mine, used an inch-pound torque wrench and tightened everything per Holley/MSD spec including the center bolts. It's been flawless since then and right now it's Africa blast furnace hot here in central Florida so I figure following the directions is the way to go. Hopefully I won't have to come back and say, oh shit, haha...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 08-18-2021, 11:18 AM   #23
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Osbornsm View Post
I recently had my Camaro at the tuner for some mystery vacuum leak.
The MSD intake manifold bolts were loose.
- Not the install bolts, the two halves were separating
Some needed torquing...
Some were only HAND-TIGHT...
Snugged everything to spec and running beautiful now.
Moral: CHECK YOUR MSD IM bolts
Just checked mine and they were also not to 75 inch pounds. Not loose but not to spec.
gmw0181 is offline   Reply With Quote
Old 08-22-2021, 01:15 PM   #24
Fraxum
Fraxum's Avatar
The same thing happened to my ported MSD on my 2016 SS. To me the LT2 is a much better performance value. With other options now maybe the MSD is not the plan even with all out bolton builds. Although it did look cool.
