Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 08-25-2023, 06:40 PM   #1
camfwin
Drives: 15 Camaro Z28
'15 Z28 Help
Looking at a '15 Z28 with less than 2,000 miles, what should I be looking at, possible issues with a low mileage Z. Carfax shows one owner, regular maintenance and no other issues. Looking for a weekend driver and possible investment down the road
I know there are quite a few knowledgeable Z28 owners on the forum that can offer some ideas and suggestions.
Thanks for any help you can provide.
camfwin is offline   Reply With Quote
Old 08-25-2023, 07:19 PM   #2
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
Hard to screw up a car in 2000 miles. Track use is about the only thing I would be concerned with for an investment car. I also don’t care for mods on investment cars either. If it’s all chipped up or PPF is hammered that would indicate track use. The rear haunches and flairs may have some peppering from the front tires. Should be minimal with 2000 miles.
Good luck.
69L48Z27 is offline   Reply With Quote
Old 08-25-2023, 07:20 PM   #3
69L48Z27
69L48Z27's Avatar
And if it has original tires you can count on replacing them if you want to drive it.
Old 08-25-2023, 09:19 PM   #4
camfwin
Thanks for the info, it's had the tires replaced, no aftermarket items and carfax reported front struts replaced at 700 miles and at least 2 oil changes.
Old 08-26-2023, 05:32 AM   #5
69L48Z27
69L48Z27's Avatar
Front struts replaced? I would want to find out why, that’s not something that was common. Here’s the challenge with that. Struts on the car are from MultiMatic and not used on any other production car. They also have specific labels with ‘Z/28’ on them and the VIN number. From a functional perspective I would assume they were replaced under warranty and MuliMatics went back in. From a 50 years down the road perspective, the born with parts are gone now that made the car different. Other than track cars, I don’t recall seeing anyone replacing these. Even the high mileage cars still have the original struts.
If you find out why they were replaced, report back if you don’t mind. Curious why at 700 miles they needed replaced.
I guess over all it’s not a ‘big’ deal or anything that should hold up a deal. Just make sure they put MulitMatics back on.
Old 08-26-2023, 07:16 AM   #6
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
There's really nothing specific about a Z that wears out early or anything. At 2000 miles it should still be minty fresh. As others said check the tires, and possibly the battery. Both are likely the originals and are 8+ years old now.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 09-03-2023, 08:35 AM   #7
FLOW TIE
FLOW TIE's Avatar
Drives: 2015 Z/28 #898
Are the MultiMatics still available?
Don’t they use the same ones on the ZL1 1LE ?
FLOW TIE is offline   Reply With Quote
Old 09-03-2023, 08:54 AM   #8
1970judge
Drives: 2015 Z/28, 2007 HHR
No and No
1970judge is offline   Reply With Quote
Old 09-03-2023, 09:14 AM   #9
pzero
pzero's Avatar
Drives: 2015 Camaro Z/28 #968 Silver Ice M
With only 2000 miles on it and knowing it’s 8 years old. Only thing I would replace is tires and all fluids, (radiator flush, trans, engine oil, rear diff, and brake/clutch fluid. After that check all rotors/pads, and multimatics suspension. Only thing I worry as our Z age, rotor replacement and multimatics suspension replacement. They don’t make them anymore.
Current Cars:
2008 Honda CRV 2.0L
2015 Chevy Z/28 7.0L
2016 Chevy Tahoe 5.3L
Past Cars:
1976 Chevy Malibu Classic 5.7L
1985 Chevy 2DR 4x4 Blazer 5.7L
1989 Chevy IROC-Z 5.7L
1995 Chevy 2DR 4x4 Tahoe 5.7L
2005 Chevy 4DR Tahoe 5.3L
pzero is offline   Reply With Quote
Old 09-03-2023, 10:24 AM   #10
CamayroZ
Drives: '15 Z/28
FWIW carbon composite rotors can be restored/re-deposited. There are 2 companies that do this kind of work in Europe. I am aware of Surface Transformers and they have done this for a couple of Porsche track friends. Our rotors are basic Brembo rotors and nothing unusual about them.
CamayroZ is offline   Reply With Quote
Old 09-03-2023, 09:58 PM   #11
pzero
pzero's Avatar
Key word, there are 2 companies in Europe. How much will it cost is the main issue. I wish there metal rotors for our Z. I don’t track mine so I would substitute for metal for carbon for time being if I can.
Current Cars:
2008 Honda CRV 2.0L
Past Cars:
Old 09-04-2023, 01:48 AM   #12
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
. I wish there were metal rotors for our Z..
Your wish has been granted.
ariZona28 is offline   Reply With Quote
Old 09-05-2023, 11:13 AM   #13
highrevving
highrevving's Avatar
Drives: Z/28
Parts availability keeps me up.....
highrevving is offline   Reply With Quote
Old 09-05-2023, 09:11 PM   #14
pzero
pzero's Avatar
Arizona, thanks for the info. Now if you can find me some substitute struts…LOL.
Current Cars:
2008 Honda CRV 2.0L
Past Cars:
