dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 04-09-2023, 10:58 AM   #1
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
PO Code 2099
any one have a run in with this code
everything checks with a code reader, All O2 sensor seem to be working
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 04-09-2023, 12:41 PM   #2
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
Service manual says
Exhaust leak
Low fuel pressure
Engine vacuum leaks
Fuel contamination
Lean fuel injectors
Says it isn’t o2 sensor without other codes
Basically engine is running lean during 17-65% load and trims can’t correct enough.
gtstorey is offline   Reply With Quote
Old 04-09-2023, 01:22 PM   #3
spyderbuddy
Originally Posted by gtstorey View Post
Service manual says
Exhaust leak
Low fuel pressure
Engine vacuum leaks
Fuel contamination
Lean fuel injectors
Basically engine is running lean during 17-65% load and trims can correct enough.
That's different?
thanks
