Old 10-11-2023, 12:10 PM   #1
Ead731
Drives: Camaro ZL1
ZL1 flex fuel sensor
Hi everyone. 2019 zl1 m6 here. I’m looking to install a flex fuel sensor so I can run ethanol with my pump gas. I do not want to run an entire tank of ethanol, again just a mixture. I’ve attached a video from YouTube where a girl installed a flex sensor to run a mix of e85 and pump gas. Is this something that would work for what I’m looking for. Excuse my ignorance on the question, I’m new to the ethanol game and don’t have experience with it!!
https://m.youtube.com/watch?v=SlvU6n...wgZmxleCBmdWVs
Ead731 is offline   Reply With Quote
Old 10-11-2023, 01:37 PM   #2
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
It's common, most install the DSX Flex Fuel kit. However, you will need a tune to do this.
Old 10-11-2023, 01:46 PM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Modified All Bolt On's
I just did the same to my ZL1.... It starts at post #213
https://www.camaro6.com/forums/showthread.php?t=611982
Good Luck and yes as said above you need a tune. JRE did mine remotely and it was a good experience !
2023 ZL1 A10 - CSP 2" Long Tube Headers by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port/Polish w/Griptech 2.3" Upper | Granatelli Malevolent Coil Packs | Granatelli 0 Ohm Plug Wires | Katech Valve Covers w/Coil Relocation | FI Interchillers Blower Spacer Plates | Mighty Mouse Mild | JMS Flex Fuel Booster | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | AEM w/b AFR | Banks iDash Data Monster | HPTuners MPVi3 Module and Licenses (ECU & CCM) | Remote Tuned by Ted at JRE
Old 10-12-2023, 02:36 PM   #4
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
This was my pick... before I had my Banks iDash... Great system, works as advertised.
https://www.advancedfueldynamics.com...olet~md_camaro
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
Old 10-15-2023, 01:50 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
get a flash file from Jannetty to flash after the install. He will do it right and it will be safe.
Old 10-15-2023, 04:41 PM   #6
2023_ZL1-AUTO
+1
