04-01-2018, 01:31 PM | #71 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
I just recorded a quick pull yesterday to see what mine is making stock. It was right in the middle of the 2nd and 3rd lines, which equals 9.375 psi. So it's pretty much dead on the factory rating. Guess I'll have to check the bypass butterfly to see if it looks like it's sealed shut. If not, I may try to set it and retest for a gain in boost. It'll be a while though. Weather is showing rain for the next several days.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
04-01-2018, 01:33 PM | #72 | |
Drives: 17 ZL1 Join Date: Mar 2017
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
04-01-2018, 01:39 PM | #73 |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
This thread and little procedure should be a sticky
04-01-2018, 05:23 PM | #74 |
Drives: ZL1/335i Join Date: Apr 2014
I’m going to see what this does on mine. I have a real boost gauge (P3 vent gauge), and also have logs showing my boost. Trying to determine boost based on the vague factory gauge isn’t the best test IMO.
I’m sure it’s been mentioned here, but throttle closure is the main reason for boost lower than the ~9 psi specification. Mine was bad after installing a Roto-fab. After dialing in some tables with HPT, I was seeing close to 11 psi. This was a result of keeping the throttle open, and likely some boost gains from reduced intake restriction. Now I have headers, and it’s close to the stock number — as the gain from the intake and loss from the headers have more or less cancelled each other out. |
04-02-2018, 11:46 AM | #75 | |
Drives: 2018 ZL1 A10 Join Date: May 2017
04-02-2018, 01:20 PM | #76 |
Drives: Camaro Join Date: Mar 2017
Adjusting this is only going to make boost go up if it was set incorrectly from the factory or if somebody had it off and was screwing with it. Boost is also relative to your elevation and density altitude so it's a variable. For 99% of the people this will do nothing for you.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
04-02-2018, 01:55 PM | #77 |
Drives: Camaro ZL1 2018 Join Date: Aug 2017
04-02-2018, 03:43 PM | #78 |
04-02-2018, 10:10 PM | #79 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
The problem with threads like this is that they give the impression that 90% of the bypass valves come mis-adjusted from the factory.
If you think about it, all GM does is bolt the supercharger to the block. Adjustment of the bypass valve is done by Eaton when they assemble the SC. This would explain why there are no instructions for adjustment in the GM service manual. I've seen boost as high as 9.4 psi through the P3 gauge on my car so I'm confident my boost bypass valve is adjusted to spec.
04-02-2018, 10:23 PM | #80 | |
04-02-2018, 10:36 PM | #81 | |
Thank you Al Oppenheiser!
04-02-2018, 11:23 PM | #82 | |
Coupe Newbie
04-02-2018, 11:31 PM | #83 | |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
04-03-2018, 06:56 AM | #84 |
Drives: 2017 Camaro SS 1LE Krypton Green Join Date: Sep 2017
I imagine there could be some concern with the actuator bottoming-out repeatedly or the bypass throttle blade over rotating and contacting the seats (not sure if that term is correct)?
Tags |
adjustment, boost, bypass, lt1z350 |
Thread Tools | |
