10-16-2017, 11:15 AM | #1121 | |
Camaros Of Northwest Ohio
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
10-16-2017, 12:10 PM | #1122 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Thanks! I don't have an official baseline time or dyno. I honestly didn't plan on modding during last winter. But according to my cars timer, 12.7 stock was the best i could get. Since then I've gotten the launch down better. And can get 12.2 on the cars timer. I have a couple 1.8 60's but the et was higher.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
10-16-2017, 03:46 PM | #1123 |
Drives: 2017 camaro ss Join Date: May 2017
Dubchitts, if you could do your mods over again, what would you pick as your most effective mod at the track?
10-16-2017, 04:11 PM | #1124 | |
If i had to guess e85 if you have good stations Sorry I couldn't be more helpful!
"Spitfire" 427ci
10-16-2017, 06:26 PM | #1125 | |
Bill
10-17-2017, 09:53 AM | #1126 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
2016 Camaro SS A8 - JDP Stage V
2016 Camaro SS A8 - JDP Motorsports Stage V with LME 377ci LT1, JDP Motorsports Stage 2 Head and Camshaft Package, Magnuson Heartbeat, Roto-Fab CAI, Alky Control Methanol System, KOOKS 1-7/8" LT's, LT4 Fuel Package, 20" Drag Radial.
Tires used on the pass: Mickey Thomson 305/35-20 DR Performance Mods (if any):Above Category submitted for: 5. Power adder (stock displacement) R/T.......... .324 60'............ 1.600 330'........... 4.683 660'........... 7.120 660’ mph... 99.56mph 1000'.......... 9.251 1320'.......... 11.052 1320’ mph… 126.31mph Name of the track: Rocky Mountain Raceway Date of pass: 10/14/17 Weather conditions: +3600 DA Kind regards, Jordan Priestley 801-545-4215 |
10-17-2017, 12:13 PM | #1127 |
Drives: 2016 2ss, whipple supercharged Join Date: Apr 2016
How much power is that package making? If you have a dyno sheet you could post that would be great!
10-17-2017, 12:18 PM | #1128 |
10-17-2017, 12:59 PM | #1129 | |
10-21-2017, 03:04 PM | #1130 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
Went to the track this past Friday, but did not achieve what I was seeking.
Tires used on the pass: Front: 10"x20" Stock ZL1 Tires, Rear: M/T DR SS 305/35/20 on 11"s Performance Mods: NicKey Stage II Kit, Magnuson Heartbeat, C10 Race Gas R/T.......... .328 60'............. 1.513 330'........... 4.362 660'........... 6.684 660’ mph... 106.91 1000'.......... 8.673 1320'.......... 10.381 1320’ mph…. 133.13 Name of the track: Great Lakes Drag Way- Da' Grove Date of pass: 10/20/2017 Weather conditions: DA: 35psi front/ 20psi rear[/QUOTE] Last edited by Stefano; 10-21-2017 at 03:14 PM. |
10-21-2017, 03:25 PM | #1131 |
Good job Stefano, your getting there. Just a tick behind me. You need a drag pack and you'll be able to go into the low 10.20's or quicker. You have too much rotating mass to get moving. You would save about 100 lbs with a set up like mine. Keep it up and congrats on a new best et. I have one more outing in early November and I think with cool weather like it should be I can run under 10.20@137. Forecast out look says it should be around 58-60. I'm keeping my fingers crossed for those temps.
Go back on the previous page and look out my numbers, they are almost identical to yours, my car makes it up on the big end as it usually does over most others. Excellent match up
10-22-2017, 09:33 AM | #1132 |
Been following your progress and even though we achieved similar results, they are different builds. One common aspect is the Heartbeat Supercharger which is working real well. I think I have time for one more outing too.
10-22-2017, 10:09 AM | #1133 |
Have you data logged any passes? Do you have hp tuners? If not you should buy it and log your passes. You have a bunch more mods then I do so I think there is more left in yours. What kinda HP did yours make? Is the C10 unleaded race fuel? I run the VP MS109 and it works great.
10-22-2017, 11:43 AM | #1134 |
Yes, I log my passes with HP Tuners. Here is my build thread: http://www.camaro6.com/forums/showth...ghlight=Nickey
