08-31-2018, 09:18 AM | #15 |
Drives: ZL1 1LE Join Date: Oct 2016
You guys using the rubber block add-ons at all?
08-31-2018, 09:37 AM | #16 | |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
08-31-2018, 09:41 AM | #17 |
Drives: A few Join Date: Oct 2017
Oops sorry, for their site it's just the PROMO CODE field. RockAuto is the "How did you hear about us" field.. ordered from both recently and got confused.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
08-31-2018, 09:43 AM | #18 | |
The Extensions give you an extra 1.5" of lifting height too...
-Dave
08-31-2018, 09:44 AM | #19 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
Yes. You have to as the quickjack has a recessed plate where the blocks sit. If you don't use the rubber blocks the quickjack will lift using your rocker panels. Not good.
You have to have the front bolt on ZL1addons lift points all the way back, and the rear lift points all the way forward and it just fits. If you bolt on the lift pads at the pinch weld spot below the mirrors the standard model might work, but I wanted the lift points as close to the heaviest mass as possible.
'18 1SS 1LE Black, PDR
08-31-2018, 10:17 AM | #20 |
American Gearhead!!
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor Join Date: Mar 2013
In addition to the other answers, I want to be able to use it on all of my vehicles so I will have all my bases covered. I just measures the RS as that is the shortest wheel base of my group and the 76" total length of the EXT is not an issue. Additionally, after further research I also decided to move from the 5000XLT to the 7000XLT as I am also a truck guy and can foresee using that added lifting weight in the future. It's only $155 more and I hate buying things twice!
08-31-2018, 11:44 AM | #21 |
Drives: E92 BMW M3 Join Date: Oct 2012
These are SO awesome, I cant wait to get mine next spring. Such an awesome alternative to installing a true lift in your garage.
J-Rod Built and Matt@FSP Tuned |
08-31-2018, 12:01 PM | #22 |
Drives: 2018 Camaro ZL1-1LE Join Date: Jul 2012
Has anyone used their Quick Jack to do a header install? Just wondering if it gives you enough additional lift (vs jack stands) to help simplify the install (by giving you a better angle at sliding the headers up from the bottom.
2018 Camaro ZL1/1LE
08-31-2018, 12:13 PM | #23 |
I plan on it when the time comes.
08-31-2018, 12:57 PM | #24 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
These are pretty sturdy? Looking at the the pictures I'm a little nervous about getting under a car on them.
08-31-2018, 01:25 PM | #25 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2018
Im on the same boat as you, also keep in mind there are locks on this thing though. Which is like a fail safe. I suppose my biggest concern would be it buckling from the sides. I was hoping someone would share their experiences with it. I.e., has anyone been smushed - for lack of better words
Current:
2018 1SS 1LE - stock Past: 2008 C6 - heads/cam/boltons 2005 GTO - cam/boltons |
08-31-2018, 02:24 PM | #26 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
Where are the EXT in stock? Got a link?
08-31-2018, 02:26 PM | #27 |
Full Fledged Member
When I first assembled mine I left my 4th gen in the air all night. Figured if something was gonna fail I'd rather know right away lol Had the 6th gen in the air a couple times, no issues. Just be sure to use plenty of teflon tape when assembling the hose.
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2 |
08-31-2018, 02:53 PM | #28 | |
The hydraulic cylinders are for raising and lowering, not meant to hold a vehicle all by themselves. Had my car in the air over 24 hours, no problem. When it comes time for tires, I will remove them and just take the wheels and tires to the tire shop, leave the 1LE safe at home.
