Vararam
Old 12-24-2018, 10:50 PM   #771
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Thanks!
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
edog is offline   Reply With Quote
Old 09-10-2019, 06:30 AM   #772
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
I own a 2014 Camaro 2LT/RS that now has just turned 30K on the clock. Car is always garaged and well taking care of. Recently (5,000 miles) put on new factory OEM wheels and Pirelli P Zero tires, when doing so I reluctantly took her to the local Chevrolet dealership for a front end alignment even though previous tires wore perfectly, no complaints of handling.
They charged me $119.00 for 4 wheel alignment and another $11.65 for shop materials?
Fast forward 5,000 easy miles and I rotated my square setup front to rear. I noticed the tires that came from the rear is feathering or scuffing on the outside of the tires? From what I read this has to do with "toe in".
After researching local shops I have found one that others have highly recommended. Today at 11 she goes in for another alignment, this will be about 5,025 miles since last. Cost for this shop is $69.00 for 4 wheel alignment and ZERO cost for shop supplies, which they didn't understand either?
I have read thru majority of this section and having a difficult time honing in on the "stock" factory specs for a 2014 2LT/RS Camaro.
Deputy347k9 is offline   Reply With Quote
Old 09-23-2019, 03:48 AM   #773
imponte
imponte's Avatar
Drives: '10 Camaro SS
Hi guys. I just installed the Hotchkis 1 inch lowering springs on my 2010 Camaro SS Auto. I have stock 20' wheels with stock tyre dimension. I need alignment. What is the best numbers for street using? @Hotchkis
imponte is offline   Reply With Quote
Old 09-23-2019, 06:27 AM   #774
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Best numbers in this situation are more about your driving and how hard you generally take corners. If you can describe your corner driving as mild, the factory preferred specs should work quite well. If it's more like 'moderate' to sometimes a bit harder than that, I think there are some 'performance street' alignment suggestions somewhere in this section (if not in this thread) that suggest the use of cambers around -1° or a bit more up front and about a quarter degree less negative than the front for the rear.
Norm
Definitive GT500 Thread garagelogic Chevy Camaro vs... 98 02-12-2010 01:14 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 07:58 PM
Suggestion: Explanation to thread starters for their threads being locked? colin911 Site Related Announcements / Suggestions / Feedback / Questions 2 12-06-2009 10:25 PM
Dealer Praise Thread (Not an Idiot!) RPO_Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 84 06-25-2009 01:00 AM
prices thread nimnels 5th Gen Camaro SS LS LT General Discussions 1 05-02-2009 06:47 PM
