Old 08-15-2019, 01:22 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
full ZL1 brake conversion
I might be getting a set of take off ZL1 brakes front and rear. I will be getting the rotors and calipers with pads only. what else would i need. the rear rotors are bigger than the stock SS rotors.
Old 08-15-2019, 09:13 AM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Just need rotors, calipers, and pads for all 4 corners.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 08-15-2019, 09:32 AM   #3
JCunningham
Drives: 2017 2SS M6
i know i will also need backing plates for the front. dont know about the rears. the rear rotors are bigger on the zl1
Old 08-15-2019, 04:03 PM   #4
Alpha1BC
Alpha1BC's Avatar
Ah, yeah dust shields on all 4 corners as well if running those.
2017 SS 1LE.
Old 08-15-2019, 07:43 PM   #5
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
For those of us who have done it:
Front: Rotors, Calipers, Flex Hoses, Dust Shields, Pads
Rear: Rotors, Calipers, Pads
On the rear, the flex hoses and dust shields are the same as the SS 1LE.
RUQWIKR is offline   Reply With Quote
Old 08-15-2019, 10:05 PM   #6
JCunningham
Drives: 2017 2SS M6
so it does require hoses? i just have a SS not a 1le.
Old 08-16-2019, 06:23 AM   #7
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Fronts, not rears.
Old 08-16-2019, 07:45 AM   #8
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Put your track heat shields on that came with your car
Old 08-16-2019, 08:02 AM   #9
L78toLT1
L78toLT1's Avatar
Originally Posted by RUQWIKR View Post
Fronts, not rears.
This
I was able to temporarily use my original front SS flex lines with my 1LE takeoff's by removing the bolt that attaches the hose to the strut. Got the correct hoses from GMPartsdirect for around 12 bucks each.
Baby Blue
Old 08-16-2019, 08:05 AM   #10
L78toLT1
L78toLT1's Avatar
OP, did you pick up the ZL1 calipers & rotors that were advertised for $650 in the members classifieds? If so, I'm jealous. I had just picked up some 1LE takeoff's for $1500 and thought I did pretty well until I saw those!
Baby Blue
Old 08-16-2019, 10:35 PM   #11
JCunningham
Drives: 2017 2SS M6
no didnt see any for $650. still in negotiations on the ones im buying.
Old 08-16-2019, 10:36 PM   #12
JCunningham
Drives: 2017 2SS M6
ill get some Goodridge lines https://www.cspracing.com/goodridge-...-ss-zl1/12299/
