07-29-2019, 06:51 PM | #197 |
Drives: 2017 SS 1LE Join Date: Oct 2015
My plates are installed, ready to try them out this weekend
07-29-2019, 08:21 PM | #198 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Enjoy them, glad your day is coming!! I'm sure you will have no complaints!!!! Question though, were yours both long stud slides, or one of each?? Thanks...
07-29-2019, 10:11 PM | #199 |
07-29-2019, 10:21 PM | #200 |
Are you running an OEM or Performance/aftermarket strut tower brace??
07-29-2019, 10:47 PM | #201 |
08-13-2019, 09:13 AM | #202 |
Update... talked to Jason this AM. He stated Tim is suppose to start TODAY sending out the appropriate long stud slide plates to those that ordered early and received the miss match studs lengths. *This only comes into play for those running a strut brace. (IE convertibles, or aftermarket/OEM performance add on)
08-13-2019, 01:37 PM | #203 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
Finally got mine installed and got the car aligned.
Since there's no specific instructions for the 6th Gen on their site, I called and got some additional info: The forward caster position is equivalent to stock. The rear position will increase caster. Mine were not shipped with the button head bolts, which are used to emulate the stock locator pins in the shock tower. They are M8-1.25, and they need to be short enough to not protrude through the bottom of the top plate so it can slide. I bought the length they told me to, and had to cut them all shorter to fit. Torque for both the caster pan head allen bolts, and the strut top mount nuts is 18-20 ft/lbs. Be careful... the caster bolts are made of case hardened cheese... just checking them at 18ft/lbs one of them started to strip on me. Since I'm running the non-R SC3's at our next track outing, and don't intend to push it that hard, I went with pretty conservative numbers (~-2.3*), and only dialed in ~ -1* at the knuckle to retain lots of wheel clearance. The setup appears easily capable of over -3* total negative if you need that. |
08-13-2019, 01:40 PM | #204 |
Drives: 2019 ZL1 Join Date: Aug 2018
Hard to tell by that pic but it almost looks like you can't back out the set allen bolts enough to change camber without dropping the strut a little? I'm hoping that is just a camera angle issue as I was hoping to maybe use two settings. Mine ship Thursday.
08-13-2019, 01:46 PM | #205 |
You might be able to get them out with the plates slid to the minimum camber position. I didn't take any installed pics previous to the alignment, so I can't say for sure.
I'm not sure what the delta is between the two caster positions, but mine was over 7* in the front position. |
08-13-2019, 01:52 PM | #206 | |
08-13-2019, 04:40 PM | #207 |
Sorry, thought you were talking about caster. Camber is adjusted via the 3 strut top mount nuts: raise the wheel off the ground, loosen the nuts, and slide to adjust camber then re-torque the nuts.
The allen bolts are for caster and must be removed to move the mount to the new location. |
08-13-2019, 06:41 PM | #208 | |
08-16-2019, 07:48 PM | #209 |
FINALLY!!! I finally received my long stud slide "plate" today!! Tomorrow may be the install day even though I'm scheduled over a week out for an alignment touch-up. Gotta say tires are holding up so far...
08-22-2019, 09:19 AM | #210 |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Looking forward to hearing how these are working after a few track days and exactly how much camber people are getting when combining some stock adjustment with these. I am looking for -3 degrees which seems possible if you dial -1 with factory setting and -2 with these plates.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
