06-17-2019, 09:26 AM | #15 |
Drives: 2018 Nightfall Gray Metalic ZL1 A10 Join Date: Feb 2018
Had the same problem. Used the thicker gasket and still couldn't hold pressure. In the end it wasn't the reservoir cap that was giving me the issue, it was the brass threads between the adapter and the bleeder. I just added a little Teflon tape and it held pressure just fine (I wish i would have thought of that sooner).
Also for those asking about what pressure; 15 psi did the job for me. Good luck |
06-18-2019, 06:46 PM | #16 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
so thick gasket? it wasnt apparent where the leak was when i used the thick, i only know after 10 minutes it had dropped 5 psi or so.
i might try again with teflon as you suggested.
07-11-2019, 01:46 PM | #17 |
What in the crap is going on here?!?
I've bled, i've flushed, i've done everything brake related to the Camaro. The motive adapter has never slipped or lost pressure. I don't understand what people are doing wrong. ---------------------------------------------------- 1. Buy adapter #: 1118 (or the whole Motive kit is #: 0118) 2. Place the smaller gasket on the inside of cap (NO not the bigger one) 3. Apply PSI ----------------------------------------------------
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
07-11-2019, 05:43 PM | #18 | |
Drives: 2016 2SS Join Date: Dec 2015
07-11-2019, 08:55 PM | #19 |
I must be lucky also...on 3 ZL1s and 4 Fifth Gen SS's
07-11-2019, 11:05 PM | #20 |
07-12-2019, 06:56 AM | #21 |
plastic cap with the thin gasket
07-12-2019, 10:12 AM | #22 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
So i got the bleeder last week and plan on using it in the coming days. Is it as easy as the directions say?
Empty the vehicle brake reservoir and fill with new fluid. Then put 2qts in the Bleeder container and pump up to 15psi and then start at the furthest wheel and crack the bleeder open until clean fluid comes out?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
07-12-2019, 10:46 AM | #23 |
Make sure to wrap the brass connection with a bit of Teflon tape to ensure a good seal there. The triangular top only seals in one of the possible three positions. Once placed on the master cylinder, try tipping the adapter side to side. If it rocks, try the next position until solid on the master cylinder. This is the part of the equation which is the difference between a good seal and spilling brake fluid. I learned this trick because of a few incidents with these adapters.
07-12-2019, 10:52 AM | #24 | |
07-12-2019, 10:55 AM | #25 |
I usually pressurize to 12psi or so...it hardly drops during the procedure...maybe to 9-10 when a refill of the reservoir is necessary.
07-12-2019, 11:24 AM | #26 | |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
I pressurized to 15psi and it didn't budge in over 15 minutes. Worked phenomenally. Biggest PITA is the whole inaccessible clutch bleeder meaning I had to go through nearly an entire $70 bottle of SRF just pumping the clutch and sucking out the reservoir to try and get fluid into that circuit. Tracked the car a full 8 sessions though and no fade or issues at all so I must have at least gotten the fluid to where it counts during the brake flush process. |
07-12-2019, 01:52 PM | #27 | |
Thanks for the info on using just a pressure vessel. I had planned on once I emptied out the master cylinder on putting new fluid in and pumping the clutch pedal several hundred times to try and flush some new fluid into the clutch system. Then once that is bleed I was going to move onto the actual brake calipers.
07-12-2019, 09:42 PM | #28 |
start by sucking as much crappy old fluid out of the master cylinder with a turkey baster or equivalent device before the procedure above...sorry, this was an omission.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold) '15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold) '12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold) Last edited by Stephen12ZL1; 07-13-2019 at 01:31 PM. |
