01-12-2017, 02:52 PM | #85 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Thanks for the how-to. It was pretty easy to do.
Used this mirror tap for the hardwire: http://www.ebay.com/itm/221707488314 Only $10.50 shipped and worked great. |
01-13-2017, 05:29 PM | #86 |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
Now that I used mirror tap for my radar... how could I also hardware a dash cam?
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
01-13-2017, 05:31 PM | #87 |
04-21-2017, 07:35 AM | #88 |
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10 Join Date: Feb 2017
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer |
06-24-2017, 10:02 PM | #89 | |
Drives: 2016 HBM 2SS 6M Join Date: Jan 2017
I installed it on the C7 Blendmount with the Escort Hardwire cord with Blue light of course (HBM SS). Really like having the mute button handy right underneath the engine start switch. Thanks for the great pics and details. Made installation a breeze. |
11-27-2017, 12:45 PM | #90 |
Drives: 2018 Camaro SS (2SS, A8, NPP MRC) Join Date: Oct 2017
I'm reviving an old thread... I have been looking around for instructions on how to hard wire up my Escort 8500 x50 radar detector and really want to use under dash power, can you update the pictures to this post if possible so i can follow? Last edited by jamoka3; 11-27-2017 at 01:17 PM. |
07-23-2018, 07:39 PM | #91 |
Drives: NFM 1SS Join Date: Jul 2018
For the life of me I can't remove the trim panel above the rearview mirror. Is this write up the same for a convertible?
Even bought plastic trim removal tools... |
07-24-2018, 04:18 PM | #92 |
Thanks to this thread and the convertible thread I was able to finally piece enough together to install a Uniden R3 radar detector with a Blendmount and mirror tap.
On the convertible the headliner has to be removed and you're only given limited access to the airbag power connection. I found it was much easier to pop out the 4" long airbag screen than to remove the plug. |
08-21-2018, 08:19 PM | #93 |
Drives: 1967 Nova Join Date: Dec 2017
Has anyone had it stop working? I did a track day and went to replug my V1connection and nothing. I checked the cable and it was firmly in the plug (white/purple) and black. I ended up sending the cable back and they shipped me a new one for good measure. I installed the new cable and no power. The unit works fine plugged in with cigg lighter so I know it’s not the V1.
Checked the airbag fuse and it’s fine and the light is off. Help? |
07-28-2019, 07:48 PM | #94 |
Drives: Camaro ZL1 automatic Join Date: Jun 2019
I don’t know if this has been touched on before but DO NOT UNDER ANY CIRCUMSTANCES USE T TAPS to try to hard wire off that airbag power and ground wire a shop I took my 2019 ZL1 did this it worked fine for about a month, hahahaha then it started shorting and turning off every time i hit a bump then stopped working all together, instead of just ordering the plug from gen5 they t tapped then tiny ass wires, long story short of course they broke AND THEY DIDNT ZIP TIE IN PLACE!! Every time it was tugged it was against those wires so i had to have all that fixed CAR STUFF SUCKS!!!!!in Louisville KY
07-29-2019, 05:29 PM | #95 |
FWIW-
I hard wired mine in by using connections at the light panel in the front center of the headliner. Cost- About $0.10 for some electrician's tape and a dab or two of dielectric grease. Just find a ground and a +12 wire that shuts off when the ignition is off (or turns off shortly thereafter when you open the door). I forget which ones they were and really don't want to pull the panel down to check, but they were very easy to find using a multi-meter. No need to run wires down the A-pillars or anything. Typical modern radar detectors don't draw enough power to make any difference. This is at least the fifth or sixth vehicle I have done this on and I haven't ever had any issues with doing it on any of them. As for T-taps, I 100% agree with Usmcdevildog. They should be outlawed for manufacture, sale and usage for any application. Spectacularly bad idea. I have had nothing but headaches everywhere I have run across them (including house wiring...!) and remove them whenever I encounter them without hesitation.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
10-09-2019, 05:23 PM | #96 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Ok.....let me first say that this is the worst vehicle I have ever encountered for hardwiring a detector (2019 ZL1).
First, I hard wired to the fuse block under the hood. (I looked at this thread and it’s methid first, but the working space is very small and my hands and fingers are large). To my astonishment EVERY DAMNED FUSE in the entire block is full hot ALL THE TIME. Key on or off makes no difference. Didn’t take long to get tired of having to power down the detector after every drive so I went back to the overhead console method. And here’s my new problem. The only purple and white wire I have is on one of the map light plugs. So I tapped in there. Yep, full hot all the time. Detector stays on all the time. So then, looking at the airbag light plug....no purple and white wire. I have a brown and white wire and I have a purple and yellow wire. I tried both of those wires and neither one are 12v hot, ever. I gave up for the moment and rewired it to the map light with full time hot. What a pain. |
10-09-2019, 07:52 PM | #97 | |
10-09-2019, 09:32 PM | #98 | |
