12-22-2015, 02:20 PM | #1 |
Drives: Used to Drive Blue Camaros Join Date: Oct 2008
Trunk Floorboard is Pretty Thin Near the Back
A word of caution - the trunk floorboard is much less sturdy than the 5th Gen fiberglass cover. The 5th Gen piece looked like a submarine hatch cover and is well braced but a bit heavy.
The 2SS trunk floorboard is pretty thin over the spare tire well and any significant concentration of weight (like a floor jack and tool boxes) will probably cause some damage. There is no bracing in the center. Great for losing weight overall but not so great if you are carrying something small and heavy. I'm using a 1/2 inch piece of plywood to spread the weight over a larger area. It worked for two trips to the track with a couple of tool boxes, floor jack and air compressor. Two 50lb suitcases were fine without the plywood because they spread the weight better. I'ts probably fine with groceries or golf clubs but I wouldn't suggest tossing or dropping something heavy in rear center of the truck area. I guess it's all about tradeoffs when it comes to weight - no complaint from me, but something folks should know up front rather than discover by surprise. |
12-22-2015, 02:24 PM | #2 | |
Retired from Car mfrs....
12-23-2015, 12:20 AM | #3 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
Lol. So no fat girls in the trunk....GOT IT!!!
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
12-23-2015, 12:43 PM | #4 |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
12-23-2015, 03:46 PM | #5 | |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
I don't know man... Seems like you need good weight distribution so you may need a saw if you catch my drift! |
01-03-2016, 06:42 PM | #6 |
It's all about the sloshing.... I prefer a trunk monkey myself that distributes weight in cornering...
--kC OG Trunk Monkey Racing |
