02-20-2014, 11:50 AM | #15 |
Drives: 2010 2SS Join Date: Sep 2012
if you just want to stay within the limits of the supercharger kit itself you dont really need anything unless youre gonna abuse it. the only concern is your cam specs. you might wanna change cams. and youll need a spot on tune. pretty much everything everyone else said lol...
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
02-20-2014, 11:56 AM | #16 |
Drives: 2017 Z06 / 2012 CTS Join Date: Jul 2013
Trail arms, toe rods, rear cradle bushings .. Kill the wheel hop.
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06 |
02-20-2014, 02:39 PM | #17 |
Drives: 2010 ss rs ls3 red-white rallys Join Date: Oct 2008
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
02-20-2014, 02:41 PM | #18 |
550 rwhp and I'm good....looking to spend about 8 to 9 thousand.
02-20-2014, 02:52 PM | #19 | |
02-20-2014, 02:53 PM | #20 |
Jim
Drives: 2013 Black 2SS 1LE Join Date: Apr 2013
Duh
02-20-2014, 03:00 PM | #21 | |
02-20-2014, 10:14 PM | #22 |
Thanks for all the replies...still on the fence about getting boosted..I really want to, but not sure I need to right now.
02-21-2014, 07:47 AM | #23 | ||
Keeps everything inline/straight during "violent" or rapid change of direction. Wheel hops kills your driveline. All these mods stiffen up the rear end, with a result of better traction. Plug a guy like Chase from Apex Motorsports he's an active sponsor addressing suspension needs.
02-21-2014, 09:25 AM | #24 | |
LPE Dual Fuel pumps, can be installed now in preparation for adding a supercharger, this way you are good up to 800 RWHP on an LS3 ID-850 injectors purchased with Supercharger kit to support your Cam and Supercharger Combo. Proper Pulley to match the supercharger cam headers combo. Aftermarket Performance Suspension parts, starting with Trailing Arms and Toe links and a good Alignment, this can be done at the same time as the Fuel pump install when you drop the Cradle. A 3 Bar Map sensor so the computer can read boost and properly calculate injector pulse and fuel pump control. Proper tuning to bring it all together. I would be happy to write you an estimate with just the components you need to complete your build. Ted.
www.jannettyracing.com
02-21-2014, 10:39 AM | #25 | |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
Most shops charge $1000 just to install a S/C. That was only parts except the dyno tune. My buddy and I installed everything in my garage. Before selling parts cost was $9520. I sold parts $400.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
02-21-2014, 02:17 PM | #26 |
With the mods I already have, would a pro charger be the way to go?
02-21-2014, 02:28 PM | #27 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
doesn't matter...all these posts still apply. 8psi is 8psi is 8psi is still, 8psi. Pick your style or brand. The difference is where in the powerband (delivery) and how the blower makes the power.
-John S.
02-21-2014, 03:02 PM | #28 | |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Only downside to the Centri is you lose your CAI. You've got tons of great recommendations. Its now up to you to choose. Whatever you choose, you cant really go wrong. Good Luck
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
