03-22-2023, 01:42 PM | #1 |
Drives: Camaro 1ss Join Date: Nov 2019
Hi-Ram Measurements
Anyone with a Hi-Ram and factory hood willing to take some measurements for me?
I'm working with Anderson Composites to see if one of their hoods (Not the Copo) will fit over the Hi-Ram. Measurements I need are from the 4 edges of the hood to where your cut begins. And the tallest point that it sticks out of the hood.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
03-22-2023, 05:53 PM | #2 |
Drives: 18 Camaro SS Join Date: Feb 2019
Hey Tim hope this helps you out.
Also I do have the high ram and the COPO hood. Please see photo below. You will have to cut deeper into the fire wall because you also need to allow an extra inch or so of clearance because the connectors for the high ram are on the back and you don't want them rubbing against anything. If you are having a custom hood made then it might be viable if not Copo is the only option. You can tell from the photo above that my cut into the firewall was 2-3 inches deep. Then about 1 and half to 2 inches on each side of the firewall.
Previous Toys: 87 Camaro RS, 92 Camaro 25th Annive, 04 Acura RSX, 13 370z
03-23-2023, 06:17 AM | #3 | |
You say you have a COPO hood? How much room is there between the top of the manifold and the bottom of the hood when closed?
