Old 10-05-2015, 07:39 PM   #1
ramil13
ramil13's Avatar
Drives: 2015 Chevrolet Camaro 2LT RS
Disadvantages of going v6 to v8 cost wise?
I'm thinking of changing from v6 to v8 how much would it be gas wise? My current camaro costs about $120-160 a month since I drive most of the time from and to work.
My question is how much of a gas difference would it be? I know v8 eats a lot more but how much would the difference be to fill up a full tank?
Usually its $50-60 to fill up a full tank for me.
Keep in mind I live in Canada, Ontario and these prices are in CAD dollars
K&N intake, Custom Tune, Billet Catch Can, K.C's Ported 72mm TB & IM, Jacfab IM Spacer, Primary/Secondary Cat & Muffler Delete, Magnaflow Xpipe, 2.5" Straightpiped, GM Strut Tower Brace, Mace Engineering Cams, Solo Performance J pipes, Magnaflow Resonators x 2
340rwhp Dyno
ramil13 is offline   Reply With Quote
Old 10-05-2015, 08:12 PM   #2
huggett
Drives: 2015 Camaro 2SS LS3
I had the automatic V6 for 2 years and averaged 21 mpg. Traded it in for a manual SS and now average 19 mpg...... Not much difference, but keep in mind you should run premium gas in the SS. No regrets here!
huggett is offline   Reply With Quote
Old 10-05-2015, 08:15 PM   #3
ramil13
ramil13's Avatar
That sounds too good to be true.. how? doesn't v8 eat more since it has 6.2L engine but v6 is 3.6L ? Doesn't really sound like it adds up but if its true holyshit i might as well sell mine asap
340rwhp Dyno
Old 10-05-2015, 08:21 PM   #4
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
[QUOTE=huggett;8670287]It would cost the same to fill it up since the v6 and v8 use the same size fuel tank. QUOTE]
nope, V8 requires Premium, regular for the V6. Guess you could run reg on the V8(if you dare).
2010SLVRBULIT is offline   Reply With Quote
Old 10-05-2015, 08:25 PM   #5
ramil13
ramil13's Avatar
I've been running regular gas(unleaded) on mine no problems. Just to confirm, so it would be the same gas wise for a v8? Doesn't really make sense... or will the v8 just eat 2x more faster gas than the v6 will?
340rwhp Dyno
Old 10-05-2015, 08:32 PM   #6
2010SLVRBULIT
[QUOTE=huggett;8670304]
Originally Posted by 2010SLVRBULIT View Post
True..... I always ran premium in the v6 also
I didn't notice significant difference in performance when I used Premium vs Reg on my V6, so I don't bother. More of a placebo effect, if any.
Old 10-05-2015, 09:41 PM   #7
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
My cammed LS3 gets 23 to 24 mpg regularly on the interstate as a DD. 90% interstate and 10% city driving. I run premium. Anything less and you get bad spark knock. If you can keep your foot out of it and the rpms down, it will surprise you. I am running around 1700 rpm at 70mph, so the engine is not doing very much. Gotta be disciplined if you expect to get good mpg in a V8, but its fun when you throw that out the window on occasion.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 10-05-2015, 09:52 PM   #8
1sweet11SS
1sweet11SS's Avatar
Drives: 2011 2SS/RS Camaro
Info taken from my car from my last trip to Vegas:
223.9 Miles
79.7 Average Vehicle Speed
22.8 Average Fuel Economy
2018 ZL1 A10
2011 2SS M6. CAI, ATAK, OBX LTs (JRE tune)
Autoclub Dragway Best ET: 12.785 Dec 3, 2011.
Autoclub Dragway Best MPH: 112.01 Jan 7, 2012
1sweet11SS is offline   Reply With Quote
Old 10-05-2015, 10:04 PM   #9
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
My cammed 1LE got 24 mpg on the highway going 65 on 93 octane
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 10-05-2015, 11:49 PM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
Yep same here 24.3 mpg
62nalide is offline   Reply With Quote
Old 10-06-2015, 12:03 AM   #11
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Not much mileage difference for the highway. I drive up north in az twice a month and in my v6 I would make it there and back and have about 1/3 of a tank left by the time I got home. I now have a cammed LS3 with 3.91's and have 1/4 tank left when I get home after the same drive. Pretty good if you asked me
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 10-06-2015, 12:05 AM   #12
SilverSS1LE
yea i also had 3.91's in my 1LE
Old 10-06-2015, 09:23 AM   #13
Bodywerks
Drives: 2015 2SS/RS/1LE
V6 drivers probably tend to get on the pedal harder around town since they lack the torque down low, and overall power in general.
It really all depends on how you drive. Guys claiming 19mpg probably don't get on it too often, or they spend a lot of time on the freeway. I drive mine like I stole it and even though I don't really speed, if the limit is 45 I often try to get there as quickly as possible!
If you drive around town a lot, stop light to stop light, and drive the v8 camaro as intended, expect 13-14mpg. If you freeway, 17-19 is probably about right.
Also, you can run regular all day long, just expect a little less power. The ecu will retard the timing automatically.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 10-06-2015, 03:45 PM   #14
ramil13
ramil13's Avatar
Thanks for this information, probably was the most useful one.
Whats your estimate of how much you spend a month on gas by just driving in town such as stop light to stop light? (in USD dollars not MPG or CAD if possible)
I barely use the freeway and do town driving alot i spend around $150 a month on regular gas but as you mentioned I also push the gas much harder.
Would appreciate if you can give me an estimate on monthly gas costs so I can compare? Also the longer u drive the more gas it will be compared to a v6 right? because v8 engine is 6.2L but v6 is 3.6L
340rwhp Dyno
