Old 06-16-2022, 08:20 PM   #1
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Conservative tune help me get 50/100 hp more
1 have a 2011 Camaro SS a6. Recently I completed my 1st dyno tune on e85 and made 602hp / 539 tq pushing 12 psi but I thought I would of been closer to 650.
Since I’ve fallen short, now I want to chase these numbers and see if I can hit 650/700rwhp goal!
My motor mods:
LSA blower
BTR stg 2 cam 227/242 .614"/.592"
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion
Ls3 timing/valley cover
Dod/vvt delete
Dsx flex fuel e85 sensor
Dsx aux fuel pump kit / braided lines
Id1050x injectors
ZL1 fuel pump,
Griptech 2.55 pulley
Solo performance Mach ll 2.5 catback exhaust
1” 7/8th Lt headers w/ 2” titanium black wrap
Mighty Mouse wild catch can w/ -12 an lines
Cold air inductions 4” modified cai
Stock throttle body
MSD wires
Ngk iridium plugs
Edelbrock reservoir
Bosch pump Braided lines/an fittings
Gm ZL1 heat exchanger
LSX innovation tensioner 6-rib
Aero force dual A-pillars gauges
Gm stock ss lower balancer 8.00 (I think?)
The tuner mentioned I’m at 15* timing. I feel like I’m restricted on my tb, cai & catback exhaust.
So I need suggestions on new parts or recommendations on parts I have that I should replace with upgraded versions.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 06-16-2022, 08:24 PM   #2
Mr2Hard2See
Here’s my dyno vid but it may not be what you’re expecting because the shop asked me not to film inside while the car was on the rollers.Name:  6DE201D9-3E18-49DE-B307-1D1A02909A2F.jpg
Size:  149.0 KBhttp://youtu.be/8L59mWWdoFw
Old 06-16-2022, 08:36 PM   #3
Mr2Hard2See
Also I have a stock ZL1 balancer and a Dsx 8 rib 10% overdrive pulley for extra parts. I know to use the od pulley that would require me to purchase ati damper. Should I sale these extras or keep for my build but if I use them how will they effect my overall performance hp/boost levels.
Old 06-16-2022, 08:48 PM   #4
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Yeah, your tune is definitely conservative if it was tuned on E85, and only set a 15* timing. The stock TB will support a fair amount of HP on a PD blower. I made 806rwhp @ 10psi on E85 with a Whipple, 227/243 cam, ported stock heads, LT 1-7/8" headers, and full 3" exhaust.
Buy the ATI balancer and throw on the 10% OD pulley. It will make all of your numbers go up.......HP=up, TQ=up....fuel consumption=up....smiles=UP!!!
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 06-16-2022, 09:11 PM   #5
Mr2Hard2See
-Scott
Scott thank you for the feedback. I knew the ATI balancer was a good start. Do you or anyone else know where my timing should be? Also some a/f numbers I should look at?
Old 06-17-2022, 07:58 AM   #6
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
A general rule of thumb I have seen for forced induction is your NA power output should be replicated for every atmosphere of pressure (aka bar, or 15 psi). At 12 pounds you're looking at almost double. Looking at the mods you should have been around 400 NA, so I would expect numbers over 700. Agree with Scott, that's a conservative tune for sure.
joshnmn is offline   Reply With Quote
Old 06-17-2022, 08:01 AM   #7
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
It also could be a miss-calibrated dyno, at least partially
gtstorey is offline   Reply With Quote
Old 06-18-2022, 11:31 AM   #8
Beefsquatch
Beefsquatch's Avatar
Drives: 2010 LS3 camaro
5 inch intake and bigger quality tb and retune is what ive seen for the PD guys, hell Bo white has a 5in on his NA build and that guy knows alot!
2010 Camaro SS M6: TorqStorm Supercharger. CCP Jam Cam. Speed Engineering 1 7/8 LTs. Catless. Elite Engineering Catch Can. Tuned by Speed Tech Tuning. BMR 1/1.2 springs/trailing arms.
Beefsquatch is offline   Reply With Quote
Old 06-19-2022, 10:46 AM   #9
Mr2Hard2See
I think these are the steps I’m going to take. New 5”, 103 tb, 10% od damper and I just started considering a stock ZL1 tc instead of a circle D unit.
I know nick williams 103 tb is a really quality piece but does anyone have an opinion about Granatelli Motor Sports 103 tb?
https://www.summitracing.com/parts/grn-gmtbls3m
Old 06-19-2022, 11:20 AM   #10
joshnmn
2&THEHIT
joshnmn's Avatar
Never heard anything about that one. Snakeeater also makes one cheaper.
Old 06-19-2022, 12:00 PM   #11
Mr2Hard2See
I’ll check that out because I never heard of yours…haha, research time.
Old 06-20-2022, 06:20 AM   #12
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
That timing is what you'd run on 93 octane... costing you quite a bit of power. I'd guess you could run 4-5 more degrees no problem... probably pick up 30-40hp.
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 06-20-2022, 05:01 PM   #13
Batmanntexas
I forgot to mention that my numbers were all achieved with a ported stock TB.
I went and looked at my timing tables, and I am seeing 18* for 93 octane, and then there is additional timing added for alcohol. The amount if timing added depends on the percentage of alcohol content in the fuel.
As for an A/F ratio, for a boosted application, 11.5 is plenty safe (pump gas).
-Scott
COTW 9/8/14
Old 06-20-2022, 06:35 PM   #14
cc-rider
It’s all in the timing. 15 degrees is insanely low…especially on E85. Could be that the tuned for pump gas but then didn’t set up the right transfer table for the ethanol sensor? You can search here and read many posts about how much timing people are running on E85 with a build like yours.
Pulling timing back is a failsafe way to protect a motor. To be “conservative”. But timing adds a ton of power too. Max power always runs on that ragged edge.
cc-rider is offline   Reply With Quote
