Old 01-15-2019, 10:43 AM   #1
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Mrr228 valve stem
So I bought these rims and I’m aware I need 1” stems but who are you guys purchasing from? I can’t seem to find them. Found a thread on here someone posted but another member tried those stems and said they were to wide to insert in the rim. I need at least 2 of them to clear my front roller skates. Thanks in advance
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 01-15-2019, 12:37 PM   #2
HDRDTD
Why not try the same place that sold you the rims?
Might also try Tirerack ?
Old 01-15-2019, 01:18 PM   #3
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
Mine were installed at Discount tire. along with the stems /TPMS transferred from my factory RS rims.
12blkgrayRS is offline   Reply With Quote
Old 01-15-2019, 01:45 PM   #4
Mr2Hard2See
I did try the company I bought them from but they didn’t have them at this current time. I skipped tire rack and came here to get the exact 1’s that fit instead of a generic set sent out. I actually bought 22” and was informed that I would not have valve stem issues because it’s not a 20” setup.
Old 01-15-2019, 01:47 PM   #5
Mr2Hard2See
Thanks, I definitely have them swap stuff over
Old 01-15-2019, 07:07 PM   #6
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
If you're referring to the front's you'll need 1" valve stems if you have brembo calipers. Since you have 22s you might be ok.
StingrayblueSS is offline   Reply With Quote
Old 01-16-2019, 06:43 AM   #7
blewbyyou
blewbyyou's Avatar
Drives: Dusk SE
I would just change the pads (super easy) and no more worries with clearance or dust.
Daily Drives Dusk SE 2SS/RS
blewbyyou is offline   Reply With Quote
Old 01-17-2019, 04:21 PM   #8
Mr2Hard2See
MRR Wheels gave me this info and I thought the stem problem was an issue for all rims before I had contacted MRR customer service. Anyhow like I stated once before it’s not a problem with 22’s and (stock brembo’s). I’m glad I don’t have to deal with it or change pads and now we’re all more educated on this wheel since it’s like the #1 for us 5th gens.
