07-02-2018, 04:26 PM | #1 |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
Speed Engineering headers guy come in
Well after going back and fourth several times on TSP LT’s & SE LT’s headers I’ve picked SE. With that being said I have a couple questions for you guys to answer before I place my order today. When you make your purchase it gives you options for your order. My order would be LT headers with the off road connections (basically fake cats), gaskets (maybe) and o2 extensions.
1. I heard I could just reuse my current stock exhaust manifold gaskets....is the true? 51k mileage on these guys original 2011 GM gaskets on my car now. 2. SE offers 2 gasket options paper=hell no and GM multi layer steel gaskets with hardware for an extra $30. Skip or buy? I’ve heard some stuff about the hardware so I was considering ARP bolts or reuse stock manifold hardware. I’m unsure so I need to know. 3. O2 extensions I know I need these $40 1-7/8” LT’s part# 25-1017 $284.98 GM steel multi layer gaskets/hardware $30 O2 extensions $40 Total= $354.98 I just want to make sure I’m spending money right if there’s no need to buy SE gaskets that $30 could be used elsewhere because ever dollar matters thanks.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
07-02-2018, 04:31 PM | #2 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
You’ll need new 3” clamps also
The ones that come with the headers s**k!! |
07-02-2018, 04:34 PM | #3 |
Thanks for that tip.
07-02-2018, 04:36 PM | #4 |
Drives: Black camaro 2ss 45th Join Date: Jan 2018
For the money I would get new gaskets. Cause then if you spring a leak you’re doing the labor twice. Every dollar matters you say, but to me time is also money. Rather spend an extra 30 bucks and not risk an hour more of work down the road
07-02-2018, 04:44 PM | #5 |
Sounds good and I’m not that critical about the money situation I just rather not have to do things over and over for labor or purchase. Trying to Research things thoroughly to buy once. I played that game with an used Borla touring axel back that I didn’t like but I sold it for profit. I have solo performance Mach xl catback with j-pipes so these LT’s should get my sound bug and performance up
07-02-2018, 05:18 PM | #6 |
I just ordered the complete kit it was cheap so why not. Now if anvil auto can stop taking forever on carbon fiber I can maybe get the look I want before summer is over.
07-02-2018, 06:00 PM | #7 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Hopefully you ordered different clamps as stated above.
2014 2SS/RS LS3/M6
07-02-2018, 06:17 PM | #8 |
I haven’t done that yet. You guys have a good source to recommend? Picked up some lift pads and sct x 4 from Dyno Steve as well.
07-02-2018, 06:29 PM | #9 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
get the GM gaskets and the o2 extensions. i would also get 3" lap joint clamps for the mid pipes
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
07-02-2018, 06:40 PM | #10 |
U guys buying clamps from SE or local auto parts/exhaust shop? Summit racing /jegs etc. I don’t want leaks and I thank you guys in advance
07-02-2018, 06:46 PM | #11 |
Drives: 2013 2SS/RS Join Date: Nov 2015
Got mine from canadian tire. 15 bucks each. Any 3" × 3" stainless band clamp will work fine. I ended up replacing all 4 because the factory 2.5" clamp bolts were no good.
07-02-2018, 07:17 PM | #12 |
Right on fellas. I’m gonna be a happy guy soon. Since I just ordered a few things I bet my work schedule is going to go nuts and I won’t have time for car stuff. Murphy’s Law I just know it. I can buy those clamps local
07-02-2018, 07:31 PM | #13 |
Started#gottalovethatblue
Get ready for some fun! I have LT’s with cats and Solo Mach XL Catback. Here’s some post tube fun for a general idea of what yours will sound like:
https://youtu.be/AMHOUyTE9Jo
07-02-2018, 07:47 PM | #14 | |
Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
I didn't need the extensions, the clamps do suck, and I reused the GM gaskets for around 25,000 miles before I eventually had to trade her in. Enjoy! I really enjoyed those headers, great value for what you got.
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
