01-27-2021, 03:58 PM | #15 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
03-02-2021, 01:20 PM | #16 |
When I finish installing the new TB, I reset the fuel map and start the lelearn process ....
After what time (miles) can the lelearn process be considered complete? |
03-09-2021, 11:18 AM | #17 |
I finally took the time to install the new ported throttle body.
The installation went smoothly. The only thing that surprised me were the narrow screws on the large holes throttle body. So I centred the TB at the intake manifold at least a little to the touch. I was pleasantly surprised by the clean intake manifold. The oil catch can seems to work well. I pulled out fuses 20 and 5 to reset the ECM. The first start and perhaps a test drive will take place the day after tomorrow. |
03-09-2021, 11:30 AM | #18 |
I won one of the first ones he did for the C7’s cause he owned one and I’m completely satisfied.
Orange Krush II
03-09-2021, 12:08 PM | #19 |
03-09-2021, 02:27 PM | #20 |
Good deal sir!! Should be a nice addition to the throttle response for sure..
03-11-2021, 11:53 AM | #21 | ||
I reset the fuel map and today I started the Camaro after 6 months of standing. Engine started on the first try. The RPM increased slightly, but the ECM immediately retracted the idle to normal. After all, the video says more than 1000 words. I need to drive some kilometers and start road lelearn proces. But the weather is bad here. But even now, the response to the accelerator pedal is noticeably better. We'll see what I install the TB contorler. |
03-12-2021, 01:17 PM | #22 |
Today the first 34 kilometers.
The car drives like crazy. But this will probably be an ECM reset. The response of the accelerator pedal is not as sensitive as I would like, but the TB controller will fix it . But very good for now! |
