11-29-2020, 06:30 AM | #1 |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
Last question about oil
I need to fill some oil after 550 firsts miles. I think I’m gonna change thé oil at 1200/1500 miles. Thé oil to fill is a 0w40. For thé moment I drive more in Town and open road (55 a 80 miles/h) but no track... i will wait for lapping done In France thé brands aren’t the same and sometimes there are not the same indexes. So here are thé 5 french brands : Castrol mobile motul elf total What is the best ? The indexes are more common in 5w40 or 5w30 is it good oil ? Can I fill it with that oil on order to make thé level ? Thanks guys |
11-29-2020, 06:46 AM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
The car calls for 0w-40 Mobil 1 ESP Formula. However, I would think as long as you use an oil that is Dexos 2, you will be okay. I believe this is still the cheapest place to purchase it.
https://www.speedwaymotors.com/Mobil...6-Quarts,37193 |
11-29-2020, 07:33 AM | #3 |
The Owner's Manual mentions 5W30 for the street so I run Pennzoil Ultra Platinum Full Synthetic 5W-30 dexos 1
'20 ZL1 1LE A10,
11-29-2020, 09:11 AM | #4 |
I changed my oil 2 weeks ago and put in Lucas 5w30 synthetic. Of course I don’t track my ZL1 and it’s a 2017 which doesn’t call for 0w40.
11-29-2020, 09:36 AM | #5 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
This is what you need. Quick google search shows it should be available in France.
https://www.cdiscount.com/auto/entre...037868488.html
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
11-29-2020, 11:49 AM | #6 |
Thanks for all advices... I’m gonna follow my swiss friend advice
I think I can easily find that mobil oil... |
11-29-2020, 01:36 PM | #7 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Since you are in Europe, I believe Castrol Edge 0W-40 should work for you. The Castrol Edge in North America is different(A3/B4), for some weird reason, and is only DEXOS 1 Gen 2 compliant. Just make sure you double check the Castrol Edge 0W-40 sold there and see if it meets DEXOS 2, which should be a blue symbol, not a green one.
Here is a list of all the oil that meets the DEXOS 2 standards: https://www.gmdexos.com/brands/dexos2/index.html Looks like you guys get the A3/B4 as well. Make sure you pick the right one, not the A3/B4 one. https://www.castrol.com/fr_fr/france...html#tab_0w-40
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
11-29-2020, 11:42 PM | #8 | |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
11-30-2020, 08:04 AM | #9 |
Everything that I read tells me these cars should be using dexos 1 Gen2 oils, not dexos 2 oils, which are for diesel engines which have to pass a low speed stochastic pre-ignition (LSPI) test.
When you don't see Mobil 1 and Pennzoil's best racing oils on the dexos 2 list... For example, Mobil 1 Extended Performance 5W-30 - GM dexos1:GEN2 Licensed - is for modern gasoline-powered vehicles (even those with high-performance, turbocharged, supercharged, multi-valve or fuel-injected engines
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 11-30-2020 at 08:15 AM. |
11-30-2020, 11:21 AM | #10 | |
I believe GM has stated that this recommendation retroactively applies to all LT1-equipped vehicles. Sent from toaster or something
Current:
11-30-2020, 11:32 AM | #11 |
I dropped mine at the dealer earlier today and told her to use 5W30 dexos 1 Gen 2 and she said we normally use 0W40 dexos 2 so I said (to myself), wtf?
'20 ZL1 1LE A10,
11-30-2020, 11:41 AM | #12 |
It doesn't matter...find whatever Synthetic in the correct weight that is on sale, change it regularly and you will be fine.
2016 NFG 1SS A8
11-30-2020, 01:22 PM | #13 |
Thank you Al Oppenheiser!
11-30-2020, 02:21 PM | #14 | |
Yes you’re right....but tins not exactly the same as the picture... Thé good one is this one ... more expensive ... |
