03-05-2020, 03:30 AM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Battery Vent
Today I bought a new battery and I solve the vent tube connection.
The battery has 2 vent holes. Should I plug in one hole on the driver's side and blind the other one? Or connect both holes into one? How is it in your Camaros Gentleman's? |
03-05-2020, 08:12 AM | #2 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
you just need one hole open and then you can plug the other. The new battery should have come with a new elbow and plug. No need to use both holes to vent
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-05-2020, 02:27 PM | #3 |
This elbow and plug battery doesn't have.
And I didn't notice if the original AC Delco had only one hole and blanking plug, or two vent holes. But Camaro have only one hose. So the battery had to have one hole and a blanking plug. |
03-05-2020, 06:42 PM | #4 |
Drives: 2013 1SS L99 Join Date: Dec 2015
Did the new battery have a red cover over the positive terminal. The plug should be attached to it. Break it off the red cover and insert into the unused hole. There's a GM bulletin on it.
2013 1SS/RS L99-GPI VVT SS1 - TSP 1 7/8 headers with Borla Touring exhaust - ESS Tuning YSI V7 - Fore Innovations Dual pump fuel system - 1" BMR lowering springs - BMR toe rods and trailing arms - Prothane rear cradle bushings - Yank 3400 Stall -
03-05-2020, 06:54 PM | #5 |
This should have come with your battery.
03-05-2020, 09:41 PM | #6 |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
If you still have the old battery you can also pull the plug out of it if you need to
03-06-2020, 01:34 AM | #7 |
Well SOAB...I thought that was just the tab used to connect the positive shield to the battery temporarily. I didn't realize you were supposed to tear that sucker off and plug your spare hole with it.
03-06-2020, 03:00 AM | #8 | |
I still have much to learn |
03-06-2020, 03:05 AM | #9 |
03-06-2020, 11:01 AM | #10 |
Drives: ABM #93 Join Date: Oct 2018
Can you get the vent tube as a replacement part? My car has an interstate in it from a previous owner and I always wondered why there was a “plug” missing from the bottom of the spare tire well in my trunk. I now know that’s where the vent tube exits the car. I have no vent tube assembly at all.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
03-06-2020, 11:20 AM | #11 | |
https://www.rockauto.com/en/catalog/...ent+tube,16762 You could probably make your own with fish tank air tubing, but for only $10 I would just go with OEM.
03-06-2020, 11:23 AM | #12 |
Thank you sir I appreciate it. I didn’t even know what I was looking for lol.
03-07-2020, 11:46 AM | #13 |
It really is there
I never noticed. Really. Anyway, it's there.... Thank you all for the information George |
