Old 09-25-2019, 11:00 AM   #1
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Huron Speed single turbo install
Thought I would show a few steps and problems with my Huron Speed single turbo installation. Hopefully this will help others and make your install go smoothly.
FrankT is offline   Reply With Quote
Old 09-25-2019, 11:06 AM   #2
FrankT
FrankT's Avatar
This pic shows how I installed an air filter. I used a Cobra head on the turbo, then a four inch 90 degree aluminum elbow to an eight inch K&N cone filter.
Old 09-25-2019, 12:07 PM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
thanks Frank! When do you plan on wrapping up the install?
joshnmn is online now   Reply With Quote
Old 09-27-2019, 10:57 AM   #4
FrankT
FrankT's Avatar
Soon, I hope. I still need to wrap up a couple of things (which I'll post here about). Then it's tuning time.
Old 09-27-2019, 01:18 PM   #5
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Look good man ! Thanks for the pics!
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 10-01-2019, 09:28 PM   #6
Beefsquatch
Beefsquatch's Avatar
Drives: 2010 LS3 camaro
Just finished the build thread lol we need more frank!
2010 Camaro SS M6: TorqStorm Supercharger. CCP Jam Cam. Speed Engineering 1 7/8 LTs. Catless. Elite Engineering Catch Can. Tuned by Speed Tech Tuning. BMR 1/1.2 springs/trailing arms.
Beefsquatch is offline   Reply With Quote
Old 10-01-2019, 11:17 PM   #7
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
I ran mine the same way to the same KN filter. I used the elbow off my old CAI. That is one mighty tight spot to route some cold air my friend. Hope you enjoy yours.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 10-05-2019, 12:01 PM   #8
FrankT
FrankT's Avatar
Here is what I did for a coolant overflow tank since they don't include one in the kit anymore. I bought a generic one liter tank from Amazon and drilled two higher mounting holes, and installed two nutserts on the car to bolt it in with a couple of 6mm bolts. I used the brass reducer from Jegs to connect the hose since the tank uses 3/8 hose and the hose coming from the radiator is a bit smaller.
Old 10-05-2019, 01:07 PM   #9
FrankT
FrankT's Avatar
I had to weld another bung in since the one that was there is in the wrong position, it puts the O2 sensor against the floorboard. The new one is clocked about 30 degrees away from the old one. I had this pipe coated, so it was a bit difficult to weld, but I think it will be okay.
Old 10-05-2019, 02:59 PM   #10
FrankT
FrankT's Avatar
I had to change the turbo drain fitting to the extended one. With the short one piece fitting, you couldn't tighten the drain hose A/N line end. It hit the turbo housing. Extending it a bit was the cure.
Old 10-05-2019, 03:22 PM   #11
FrankT
FrankT's Avatar
Connecting the heater hoses was a little different since I had changed the stock ones years ago. I clocked (or twisted) the aluminum pipes about 75 degrees, and used some silicone hoses I got from DO88, the same place I got the Cobra head from.
Old 10-10-2019, 02:54 PM   #12
FrankT
FrankT's Avatar
Here is where I ended up mounting the Mighty Mouse catch can since I'm running out of room under the hood. I made a bracket out of quarter inch plate steel and threaded the lower holes for 1/4-20 bolts, drilled the top holes for 6mm bolts and mounted it using rivnuts through a half inch spacer. I had to drop it down for hood clearance and so I could route the hoses. A tight fit for sure.
Old 10-10-2019, 05:48 PM   #13
Camaro__ss
Drives: 2013 L99
Thanks for posting. Not exactly plug and play.
Camaro__ss is offline   Reply With Quote
Old 10-16-2019, 04:18 PM   #14
FrankT
FrankT's Avatar
One more slight problem, the exhaust manifold flanges are just a bit too big. If I had to do it over, I would grind away some material around the access where the spark plugs are. A couple of cylinders are really tight trying to get the spark plug socket onto the plugs. I found a socket with a thinner wall that makes it a little easier.
