04-08-2019, 04:11 PM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
TPMS
I plan to change tires.
TPMS is from 2009, so I'm counting on the end of their life. How to proceed with TPMS exchange? I found sensors on Rockauto ,, No programming required. Install sensor and follow factory OEM relearn procedure. " What does it mean please? |
04-08-2019, 04:15 PM | #2 |
Drives: 2010 Camaro 1SS Join Date: Nov 2015
I heard it's a pain. I would just take it to a tire shop with the programming tool.
Try this: The TPMS matching process is outlined below: 1. Set the parking brake. 2. Turn the ignition switch to ON/RUN with the engine off. 3. Go to the TPM vehicle information screen on the DIC. See Driver Information Center (DIC) on page 4-27. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the DIC screen. 4. Start with the driver side front tire. 5. Remove the valve cap from the valve stem. Activate the TPMS sensor by increasing or decreasing the tire’s air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position. 6. Proceed to the passenger side front tire, and repeat the procedure in Step 5. 7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5. 8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. 9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF. 10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label. 11. Put the valve caps back on the valve stems.
04-08-2019, 04:27 PM | #3 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Here's the process I read and saved for doing the OEM TPMS matching; it's basically the same as HyperV posted:
1. Press the “Menu” button on your turn signal lever 2. Change the display on the dash until you see the tire pressure information 3. Press the “Set” button on the end of your turn signal lever to start the recalibration. It will ask you if you would like to start the recalibration, select “Yes”. The horn will sound twice informing you the process has started 4. Start with the driver front tire and release 3-4 PSI, the horn will sound once 5. Go to passenger front tire, release 3-4 PSI, the horn will sound once 6. Go to the passenger rear tire, release 3-4 PSI, the horn will sound once 7. Go to the drive rear tire, release 3-4 PSI, the horn will sound once, and then twice to signal sync is complete 8. Check the dash to confirm the “Service Tire Monitor System” message has cleared 9. Refill the tires to the proper pressure
04-08-2019, 04:41 PM | #4 |
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
I just did this, easy using above procedure.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
04-08-2019, 05:12 PM | #5 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Another option is to take it to a dealer. Mine at least will do it for free while you wait anytime, with no appointment necessary. Just drive into the service bay, and ask them to relearn your sensors. Takes about 5 min start to finish.
04-08-2019, 05:23 PM | #6 |
376 cubic inches of fun
Insist on OEM sensors unless you want to buy a "universal" TPMS tool.
But the best recommendation I can give you is: buy the tires at your GM dealer and ask for new sensors. My dealer's price on tires and installation was pretty close to internet and/or third party shops, and the result was flawless. |
04-08-2019, 05:55 PM | #7 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
2010 easy. Just a process of letting air out and then inflating. Turn signal flashes for which tire tpms to learn next. Iirc, it needs 10lb air pressure difference.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
04-09-2019, 05:42 AM | #8 |
Drives: 10 2ss/rs Join Date: Jul 2018
Its harder getting sensors off the rims than it is to program it. If you snap the old sensor off of the inside rim after tire is off rest of valve stem pulls out like normal. Just grab it with pair of channel locks and twist its a lil brass tube it breaks easy
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
04-09-2019, 01:02 PM | #9 |
HyperV117 and Welker2: That sounds clear. With that, I won't be a problem and I could do it myself. Thank you
HDRDTD and Rock-It Man: Remember, I'm from Europe. Here is not Chevrolet as Chevrolet Local Chevrolet is Aveo, Spark, Cruze, Laceti and so on So I have to do this myself like most thing. Do you have any tested parts at a reasonable price? Thank you all for your willingness to help |
04-09-2019, 04:26 PM | #10 |
RIP Betsy ( Vitara )
Not a pain pretty easy
Just a tip pull all the stem caps prior to doing reset it saves on valueable time between each tire. I also find letting air out vs putting air in is quicker on learning.
First retrofitted 2014 mylink. |
04-24-2019, 02:23 PM | #11 |
Can anyone confirm the correctness of the part number for my Camaro please...? 2010 2SS LS3 from year 2009, US version.
I chose this part. https://www.rockauto.com/en/moreinfo...888&cc=1444223 I'm confused by so many frequencies to choose from. 315/314.9 MHz, 433MHz, 315 MHz.... Thanks for every help. Last edited by George-CZ; 04-24-2019 at 02:46 PM. |
04-24-2019, 02:59 PM | #12 | |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
https://www.camaro5.com/forums/showthread.php?t=91669
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
04-24-2019, 03:30 PM | #13 | |
I will it carefully read and see what comes out of it. If it were possible to order a part directly according to the VIN, it would save a lot of time. Thank you for your help |
04-24-2019, 05:37 PM | #14 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I'm in the same boat. Finding the correct sensor for us 2010 owners is a bitch. Enough of an issue, I'm going to wait till they finally give out, then do without.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
