09-16-2018, 06:56 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jul 2018
Caliper question
Does any one have weights stuck on the front break calipers? They are just on the front and look like the stick on weights for balancing wheels. The calipers are Brembo.
Thanks.
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
09-16-2018, 07:34 PM | #2 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Like roller skates? These were to control early model brake noise/squeal:
Are these what you see? Outside of that, mine didn’t. Possible those came off a wheel in the past? If they are true wheel weights, you would not need them on the caliper... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
09-16-2018, 08:37 PM | #3 |
These? It's what is on mine. I think this was used to reduce noise prior to the roller skates.
09-16-2018, 09:12 PM | #4 |
Drives: Miss Con Ception Join Date: Aug 2016
The 2010s had the weights stuck on the calipers. Early builds had the dealers add them when a customer complained.
From ~mid 2010+ builds the brake pads came with the 'roller skates' to dampen the harmonic vibrations. If you want to rid yourself of the weights on the calipers order pads for a 2011. They will come with the dampers attached.
2011 1SS/RS LS3 CGM
09-17-2018, 07:43 AM | #5 |
Mine are like the second pic...thanks guys, I was just making sure that there wasn’t an issue that was being hidden.
