03-28-2017, 01:05 AM | #1 |
Drives: Inferno Orange-2SS Join Date: May 2015
BMR LOWERING SPRING INSTALL ISSUE
Just finished installing the rear lowering springs which are 1.25 drop. When the car is sitting on the ground everything is seated perfectly. When I lift the car and weight is off the suspension components the springs come unsteated from the upper perch mount. The shock/spring assembly has zero pressure compressing the spring. What is going on here? Thanks.
03-28-2017, 06:18 AM | #2 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
Did you click the bushings after installation, with weight on the suspension?
03-28-2017, 06:34 AM | #3 |
Not sure I know what you are referring to about to click the bushings.
03-28-2017, 07:12 AM | #4 |
Drives: 1LE Join Date: May 2015
03-28-2017, 07:48 AM | #5 |
Yes I did time all the bushings. Thats why I can not figure out what the issue would be.
03-28-2017, 08:34 AM | #6 |
Had a similar issue. You may have forgotten to install one of the retainers (like #14), which will unseat the insulator (#13) and allow the strut rod to drop when lifting the car. Or the strut rod nut is real loose, but this is unlikely to unseat the spring. Only way to check is to pull strut and mount plate and see, unless you have any access hole drilled in the trunk. Or look if you have any parts like these retainers that were not installed (ref pic of anodized retainer on top of the rear shock strut).
https://www.nationalgmparts.com/auto...omponents-scat Last edited by hesster; 03-28-2017 at 08:56 AM. |
03-28-2017, 02:05 PM | #7 | |
Drives: Camaro Justice Join Date: Jun 2007
2. Off the car, is the spring loose in the seats? |
03-28-2017, 07:22 PM | #8 |
Everything is installed correctly I've checked twice. The spring is snug off the car but not compressed at all like the front shocks.
03-28-2017, 07:30 PM | #9 |
Please post a picture of the assembled rear strut.
03-28-2017, 11:02 PM | #10 |
Back side is seated, (like the end of the coil) front side as shown is comming on seated when car is in the air. For all I know this could be normal...
03-29-2017, 03:43 PM | #11 |
Can you turn the coil easily when the car is in the air or is it tight, hard to turn?
03-29-2017, 03:57 PM | #12 |
I can turn it. It is pretty snug but wouldnt call it tight, how I'm assuming it should be.
03-29-2017, 04:20 PM | #13 | |
But that is just me. |
03-29-2017, 05:28 PM | #14 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
My BMR rears are like that when I lift the rear off the ground -- each and every time I raise the rear, I have to make sure they are aligned before I lower.
IF they are sagging I thought the BMR springs were lifetime -- maybe they can chime in -- but I believe that is normal when there is no load on the rear... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 03-29-2017 at 05:46 PM. |
