01-23-2013, 04:44 PM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
Which Melling to go with???
Will be doing a cam swap next month and looking to see which Melling oil pump to go with? I have had two good shops tell me opposites. One told me to go with the High Volume (10296) and another to go with the High Pressure (10295). Had a third shop tell me that they are pretty much the same thing. What have you cammed guys been going with?
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
01-23-2013, 04:48 PM | #2 |
Drives: cars Join Date: May 2011
Use the high volume and it will come with a spring to do stock volume. Never been a fan of high pressure.
01-23-2013, 04:50 PM | #3 |
Drives: 2015 c7 Join Date: Nov 2009
Volume
01-23-2013, 04:58 PM | #4 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
10296!!
And don't look back
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
01-23-2013, 05:01 PM | #5 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
There is no reason to run high volume or pressure on a stock engine.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
01-23-2013, 05:01 PM | #6 |
01-23-2013, 05:07 PM | #7 | |
V8 Lounge member #2
Please explain.
01-23-2013, 05:19 PM | #8 |
I am not an expert but just went through this with the guy building my short block, who is one. (Bryan at LME). He is sending me a Melling pump with the engine which is checked over and ported, but runs stock pressure and volume. More volume isn't needed except for high rpm engines and should be used with a larger oil pan. Its rare but apparently there is a risk of running the pan low of oil. High pressure is not needed with stock bearing clearances and can damage seals. This is what I was told and it makes sense to me, so I'm going with it.
01-23-2013, 05:41 PM | #9 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
10296 is what is recommended as the replacement pump been running mine on a stroker stock truck pan 25000 miles no problem
01-23-2013, 05:48 PM | #10 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Only use the high volumne in our builds. Volumne.
Pressure cost HP. |
01-23-2013, 07:43 PM | #11 |
V8 Lounge member #2
The only way your gonna run the pan dry is if you don't have enough oil with this pump or your driving upside down.
I've done many 10296's and have yet to have a problem. Volume yes, pressure no.
01-23-2013, 09:09 PM | #12 |
Burning up tires
Drives: 2023 ZL1 Vert Join Date: Jul 2010
10296 with the stock pressure spring installed that is included with it.
01-24-2013, 06:01 AM | #13 |
Drives: C6 Z06 Join Date: Nov 2010
Is yours broken? Did it wear out?
Unless you're running higher than the factory operating RPM range, or you built a motor that has looser bearing tolerances... why change it? They all have the same style reliefe piston so there is no fix if it gets hung up there... Just because people sell them, doesn't mean you necessarly need it. I don't buy the "its insurance" pitch. Insurance against what? Never heard of 1 LS engine going down from oiling issues with a perfectly fine OE oil pump.... and you never will either. From the 315hp LS1 to the 436hp LS3, they are practically identicle. |
01-24-2013, 07:41 AM | #14 |
Thanks for all the responses guys! Much appreciated!
