Old 02-08-2019, 05:43 PM   #1
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
SS Brake Upgrade - same size
What is available as a real upgrade to the SS Brakes without changing the size of the rotors/calipers? Are materials of construction or drilling/slotting significant enough an improvement to be worth the cost. I run 18" rims in the winter for snow tires, so I don't want to go bigger, I just want to go better - if it is possible. It'll be mostly a Daily Driver, but some track events are planned, so want to be sure I have a bit more bite.
Who are the reliable makers out there?
What are the best options?
Feel free to point to an existing thread, but I couldn't find one.
Thanks!!
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 02-08-2019, 06:12 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
upgraded fluid and line and pads should be enough
i ran my first track with motul 600 fluid , phastek lines and stock pads and it was fine but i have a brand new set of powerstop track day pads gonna use next time
Old 02-08-2019, 09:54 PM   #3
Calcanuck
Calcanuck's Avatar
Drives: 2017 Hyper Blue 2SS
I have done 3 track days on the powerstop track day pads. They work great and have good stopping power and modulation.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
Calcanuck is offline   Reply With Quote
Old 02-12-2019, 03:23 PM   #4
Osbornsm
Drives: 2018 SS 1LE
Brakes are mechanically fine... they DO however require more cooling.
I purchased Titanium backing plates and ducting for the brakes to keep em cool.
Caliper and rotors are fine and will not get you any benefit with same-size upgrades.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 02-19-2019, 10:33 AM   #5
Deesiel678
Deesiel678's Avatar
Drives: 2018 1LS 1LE
RacingBrake offers 2 piece replacement rotors.
https://www.racingbrake.com/RB-2pc-R...ont-p/2535.htm
Deesiel678 is online now   Reply With Quote
