09-13-2017, 11:20 AM | #1 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Newbie Question: Car between washings?
What are you guys doing between washings? When I take the car to work, there is construction going on, so it ends up with a film of dust that may mostly be regular soil from dirt being disturbed. Or not.
Do I dare try removing the dust with one of those California dusters? Or...? What are the things you guys do to try to keep the car looking nice?
09-13-2017, 11:23 AM | #2 |
Drives: '17 Z06 Join Date: Aug 2017
You could always do a rinseless wash on it. Shouldn't take more than 15-20mins to do and it'll look great afterwards. If you've never done it before or aren't familiar look at Glen e's How to's. He does a great job explaining it.
09-13-2017, 11:28 AM | #3 |
Sure, why not?
Thanks! I did read his docs shortly after getting the car, and learned a lot. I should go back and look at the part about rinseless again, as my tiny pea brain has failed to retain any detail on that.
09-13-2017, 01:13 PM | #4 |
Drives: 2016 Red Hot 2SS Join Date: May 2016
I had a similar situation, straight rinseless worked just fine.
http://www.camaro6.com/forums/showpo...&postcount=351 |
09-13-2017, 01:42 PM | #5 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
I want to see a video of someone doing a rinseless, start to finish, in 15 minutes. Fake news IMO. I've used the method and REALLY like it. But by the time you fetch supplies, mix solution, complete each panel start-finish.....I can't see doing it in 15 minutes. I'm too meticulous I guess.
09-13-2017, 01:47 PM | #6 |
Retired from Car mfrs....
I can do 15 minutes. That doesn't include wheels, nor does it include the nuance of the grill in front, just the paint. Takes five microfiber towels. And mixing it is a hassle? I put 1.5 ounce in a bucket and fill bucket… no diff than conventional wash. Ready to go.....
09-13-2017, 01:50 PM | #7 | |
Goes by really fast! 15 total is QUICK.....even using your method which I mostly follow BTW. Thanks! |
09-13-2017, 01:52 PM | #8 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
I do rinseless washes daily in my mobile detailing business. Time is everything to me. I keep my solution and rags ready to go in 5 gallon buckets with a grit guard at the bottom. I use a Tolco high pressure hand-held sprayer to wet the panel. I wipe each panel with a fresh towel using the "rolling wipe" method and the 8 sided folding method and i "flow", I keep moving. I clean the windows with a used towel. I dry with a large waffle weave towel using the "bullfighter" method. OH! And espresso. Lots of espresso!
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
09-13-2017, 02:15 PM | #9 | |
09-13-2017, 02:31 PM | #10 |
OK, after the remnants of Hurricane Irma get the hell out of here (3 days of non stop rain), I'm gonna do it!
09-13-2017, 08:17 PM | #11 | |
Rinseless or traditional wash. To figure out which one you should do, do a "swipe test" with your index finger. Using as light of pressure that you possibly can, make a light swipe across the area. If most all of the stuff is removed, do the rinseless. If most of it still remains, foam and traditional wash. Kenotek Showroom Shine Detail Spray will also help repel dust after a rinseless or traditional wash. Leaves a very anti-static surface that remains several days after applying.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
09-13-2017, 09:41 PM | #12 | |
Drives: Chevy Join Date: Jun 2017
09-14-2017, 02:23 PM | #13 |
First attempt with no strategy was 9:44.75. I will record video and post when I get a sunny day.
09-14-2017, 03:18 PM | #14 |
