11-09-2019, 10:00 AM | #1 |
Drives: Chevy Camaro SS, Chevy Corvette, Join Date: Aug 2019
Torque Convertor??
I currently have a 2011 SS with L99. Mods I have done or will be doing are as follows.
Roto-Fab CAI Kooks Long Tube Headers with Hi Flow Cats and Jet Hot Coating 3.91 Rear gears GPI SS1 VVT Cam with all supporting valve train goodies. This will be a STREET CAR ONLY. I have never had an automatic Hot Rod before only Manuals. So my experience with Torque converters is basically nil. I know this Cam can be run on the Stock Converter So??? What are the benefits and disadvantages going with an aftermarket converter? If I decide to go with an aftermarket converter which Stall Speed? 3000-3200? 3200-3400? 3400-3600? and Why??? Will it affect Streetability and how?? Thanks! Dan |
11-09-2019, 10:38 AM | #2 |
Drives: 2011 Camaro SS Join Date: Jul 2017
I think the 3200-3400 would be fine for you. I have a 3500 in mine. It's perfect NA but I think it will flash higher with my turbo kit so I would rather have around a 3000 stall before going FI. My tuner setup my car to drive as close to stock as possible until I floor it. Trust me you will love the stall.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
11-09-2019, 07:48 PM | #3 |
Drives: 2013 1SS L99 Join Date: Dec 2015
I have that cam and ran it for awhile with a stock converter. Yes it will work BUT. It is lazy in the lower RPM's and pushes at the brakes at idle. I run a Yank 3400 power adder converter. Really woke the car up.
2013 1SS/RS L99-GPI VVT SS1 - TSP 1 7/8 headers with Borla Touring exhaust - ESS Tuning YSI V7 - Fore Innovations Dual pump fuel system - 1" BMR lowering springs - BMR toe rods and trailing arms - Prothane rear cradle bushings - Yank 3400 Stall -
11-10-2019, 12:43 AM | #4 |
USA-1
It's lazy in the lower RPMs? Isn't that cam specifically made for the lower RPMs?
To the OP, I have intake, longtubes, 3.91s and a 3200 converter and it's a BEAST! A converter is by far one of the best mods for an L99. I talked to Circle D and they said the best daily driver converter is their 278mm 3200....which is what I have.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
11-10-2019, 08:17 AM | #5 |
I have the TSP Stage 3 cam with all the supporting FBO mods and run a 3600 and it is a monster, and a daily driver, it was a 3200 which was just fine, but with the cam needed just a little more. I would suggest the 3200 for your application, will turn you car into another animal !! Good luck and enjoy sir..
11-10-2019, 10:15 AM | #6 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Find out your tq peak and then your ideal stall speed will be 500rpm below. I run a 5C Circle D. For a stock cam it's the biggest I'd run. For your application, I think a 4C would be ideal if you're not gonna do anything else to it.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
11-10-2019, 05:20 PM | #7 |
Great White
Do you need to have a trans brake to run let's say a 2800-3200 stall on a l99??
11-10-2019, 07:20 PM | #8 |
USA-1
Nope...
11-11-2019, 06:52 PM | #9 | |
Just like your car became "a BEAST" with the 3200 converter. Cam's not bad with a stock converter and would highly recommend it. I didn't want anyone to think I was knocking GPI or their products.
11-11-2019, 08:35 PM | #10 | |
Dan |
11-11-2019, 09:35 PM | #11 |
I don't but I'll try to take some tomorrow night.
11-12-2019, 08:12 AM | #12 |
11-12-2019, 12:49 PM | #13 |
Stigs Bahraini Cousin
personal experience, YankSS 3600 stall even used it with stock LS2 and it made the launch like a missile. no issued with daily driving it the only disadvantage is higher trans oil temperature which later on installed a big a** cooler which took care of the issue.
shifing between gears was improved a lot, rpm drop way less which kept the car in power band range.
2015 CAMARO 1LE
11-12-2019, 09:05 PM | #14 |
