01-09-2021, 09:17 PM | #29 |
Drives: 2021 Camaro LT1 Conv Join Date: Oct 2016
People keep the factory rims on the LT1? They stayed on my vehicle a whole 2 days.
01-10-2021, 03:51 AM | #30 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
01-10-2021, 07:02 AM | #31 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
The first thing I do after cranking her up is turn on Rev Match, the second thing is switch to Track mode, the last thing before driving off is to turn off the nannies. You get used to it after a while and I like having all 455 hp and tq available on demand.
01-10-2021, 08:13 AM | #32 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
And way worse in temps below 50 degrees than a all season tire. The ultra summer performance tire is only better in the summer and properly heated and this reference is regarding street use not a road course.
01-10-2021, 08:19 AM | #33 |
I have no argument with that statement and I'm certainly not advocating running the OEM Super Car tires. As you mentioned, unless it's warm and dry they're not a particularly good tire. I'm simply pointing out that even when you have tires that big, it's warm, and it's dry, you're still going to spin if you turn off TC and go WOT from a stop.
01-10-2021, 08:29 AM | #34 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
And, you would be a pinball if you used all 455 tq on these tires. It gets squirrely with the nannies on and "mini fishtails" (which is what the OP was talking about).
01-10-2021, 08:31 AM | #35 | |
01-10-2021, 08:35 AM | #36 | |
01-10-2021, 08:40 AM | #37 |
Almost the same for me, when I decide to get aggressive, off goes traction control and I have fuse pulled for NPP, I want all horses ready to go. I also drive with minimum rear tire pressure just to keep the low tire pressure light off, I want max traction at all times. All that and a super sensitive butt meter keeps me out of trouble.
01-10-2021, 08:46 AM | #38 | |
01-10-2021, 08:55 AM | #39 |
Drives: 2017 Camaro 2SS FIFTY convertible Join Date: Sep 2014
01-10-2021, 09:09 AM | #40 | |
01-10-2021, 09:23 AM | #41 | |
Dumb Ass Deluxe
Maybe I can drive more aggressive at times? As far as rev match, I have that feature built into my right foot. Nothing like blipping the throttle as you're taking it down. A10 might be different as far as traction so I can't comment....
01-10-2021, 09:30 AM | #42 |
I have adopted a ton of respect for 1st gear in our LT1s with the nannies off riding the factory 245 runflats. I tend to lift off the throttle as soon as I hear the 1st tire squeak in 1st gear. As mentioned earlier 2nd through 6th will not spin with the nannies off in a straight away, providing dry warm conditions, abundant here down south.
