Old 09-12-2019, 10:31 AM   #113
Stingray_2014
Drives: 2019 Camaro ZL1
Originally Posted by tjward5489 View Post
I bought these for my 2019 and they are literally plug n play. No constant flow and the rear view camera shuts off when you leave reverse.
https://store.ijdmtoy.com/products/l...-20-001a-white
How have these been for you? I want to buy these but I want to make sure it's worth it and these are quality pieces as well.
Thanks
2019 Riverside Blue ZL1 M6, PDR
Stingray_2014 is offline   Reply With Quote
Old 09-18-2019, 06:55 PM   #114
tjward5489
Drives: Chevrolet Camaro
Thanks
I have had literally zero problems with them. They make a huge difference in light output from the stock. The backup camera is actually useful at night now with them.
tjward5489 is offline   Reply With Quote
Old 03-15-2020, 03:41 PM   #115
ZL1 affair
ZL1 affair's Avatar
Drives: 1of 66 Orange Crush 2020 ZL1’s
These still working well for you? Will have to get a set for my 2020... Unreal GM puts LED's in almost everything but they cheep out on the reverse, license and trunk lights.
Dreaming of a 2020 A10Crush ZL1 *TPW Sept 30* Built November 14, 2019, shipped Nov 15, 2019. Arrived at the dealer January 29, 2020.
2013 CTSV coupe 6MT SOLD
ZL1 affair is offline   Reply With Quote
Old 11-13-2020, 10:49 AM   #116
zaimer
zaimer's Avatar
Drives: 23 ZL1 6speed
Did you end up trying those bulbs? Is there anything similar? $36 seems a little steep for two little bulbs..
zaimer is offline   Reply With Quote
Old 10-25-2022, 10:06 AM   #117
workin4dabigguy
workin4dabigguy's Avatar
Drives: 2019 Chevy Camaro 2SS 1LE
I installed the iJDM Toy bulbs and they work great. They have resistors pre-installed on the bulb harness. This is a great option if you don't want to install and fiddle with your own resistors.
workin4dabigguy is offline   Reply With Quote
Old 11-14-2022, 02:53 PM   #118
dhoogerhyde
dhoogerhyde's Avatar
Drives: 2022 Camaro 2SS Convertible
Just got a pair of these from iJDMToy after picking up a set of (expensive) bulbs from Diode Dynamics. For 1/4 to a 1/5 of the price of the DD bulbs if you figure in the resistors, the iJDMToy bulbs are a bargain and are outstanding. Definitely a plug and play solution and highly recommended.
dhoogerhyde is offline   Reply With Quote
Old 10-02-2023, 06:20 PM   #119
oOKhanhOo
Drives: 2018 SS 1LE
Does anyone know the resistor specs on the gen5diy single resistor? I believe the resistor on mine is bad cause the backup cam just stays on now. Haven’t been a problem since until recently.
EDIT: I found it, 50w 3 ohms
oOKhanhOo is offline   Reply With Quote
Old 10-30-2023, 03:06 AM   #120
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Although it's an old thread, thank you OP for the detailed write up. As things have evolved a bit, would a led bulb that includes a load resistor be used instead? See below for an example:
https://www.ebay.co.uk/itm/304792111...mis&media=COPY
Old 10-30-2023, 10:31 AM   #121
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Yes and no. Some people have made their own very cheap by just buying resistors and attaching them to LED bulbs, but not every resistor works with the Camaro. Even some LEDs with resistors built in (like what you linked here) for the purpose of being backwards compatible with vehicles like this don't always work. The Camaro is picky for some reason.
I used regular halogens on my last Camaro that were just bright white. They LOOKED like LEDs and im upset they aren't made anymore. Im mad that I forgot to switch them out for the stock bulbs before trading it in so I could use the good ones on my new Camaro. Im sure there are similar options but I have been too lazy to find them lol.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
Black on black 2019 3LT RS Camaro.
1100: 3/7/19 | 4200: 4/15/19
3100: 3/15/19 | 4800: 4/23/19
3400: 3/22/19 | 5000: 4/25/19
Built: 4/8/19 | Home: 4/26/19
RideWithDanger is offline   Reply With Quote
Old 10-30-2023, 02:01 PM   #122
My wife's SUV gets these white(-ish), very high output halogens from me again and again, because what it came with from the factory is utter junk, near zero visibility driving our TN mountain roads in the dark. These bulbs are great, but their life expectancy is catastrophic, basically the brighter and "bluer" they are, the sooner they die. No free lunch, I guess (but I already have potential LED replacements lined up for the next bulb swap).
Old 10-31-2023, 08:13 AM   #123
david_acm
david_acm's Avatar
Drives: LT1
The above link 404s but they still make those. I've been using these for a couple of months now without any issues.
https://store.ijdmtoy.com/products/c...stay-lit-issue
david_acm is offline   Reply With Quote
Old 10-31-2023, 01:41 PM   #124
MakCamaro
Makis
MakCamaro's Avatar
Thanks for posting the above link. Where did you mount the resistors? Can you post a photo?
Old 11-01-2023, 08:29 AM   #125
david_acm
david_acm's Avatar
Drives: LT1
Sure thing, I used double-sided thermal conductive tape and mounted it to the metal. This image was taken before cable routing so disregard the mess.
Old 11-01-2023, 08:54 AM   #126
MakCamaro
Makis
MakCamaro's Avatar
Thanks David.
