05-16-2022, 04:04 PM | #43 | |
Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD Join Date: Nov 2021
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover Charger sold! Better to sell, than waiting to be stolen... |
05-16-2022, 04:38 PM | #44 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
05-16-2022, 04:52 PM | #45 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
Take off the wheels and ceramic coat them or drop them off somewhere that will. 250 miles later mine are still spotless. 12 month ceramic on them.
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
05-16-2022, 08:01 PM | #46 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
05-16-2022, 08:45 PM | #47 | |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Also, is the shortest possible braking distance really the end all and be all? When you're shopping for a car, do you only buy the car with the shortest absolute braking distance, just for that "extra 5 inches"? I'm guessing not. It's a balance of many competing factors and there's no one car that can achieve all of them. Nigel |
05-16-2022, 10:31 PM | #48 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
I still have the stock pads on my SS 1LE, but I used the Z26 pads on my C4 Corvette, which was heavily modified with about 2.5x stiffer springs over stock, 11" wheels and 315-width competition tires (BFG Rival S, Yokohama A052, or Hoosier A7s) and a built 396 stroker (at least as fast as a ZL1 in a straight line)...but on stock J55 brakes (2-piston PBRs, nowhere near as good the Brembos on a 1LE). For street and heavy autocross use they worked really well. As others have said, they would overheat and not be appropriate for multiple laps on a road course because that's outside their heat range. Based on one track day at the Autobahn south course (Joliet, IL), I'm not even sure the stock 1LE pads (Ferodo DS2500, I believe) are up to the task. I'm seriously considering running z26 pads for street and autocross duty and swapping in dedicated track pads for the 2-3 track days I expect to do each year.
Matt Miller
2020 SS 1LE |
05-17-2022, 06:03 AM | #49 | |
05-17-2022, 07:02 AM | #50 |
Yes, I'm sure. With either pad, if you're into the ABS the behavior will be the same. Whichever pad has a lower and more stable coefficient of friction, you might actually have more ability to modulate before getting into ABS.
Matt Miller
2020 SS 1LE |
05-17-2022, 07:16 AM | #51 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Here lies a Z26 pad user. If only he'd not swapped those pads.
RIP |
05-17-2022, 07:20 AM | #52 | |
LOL...Right! As mentioned in previous posts... I notice ZERO difference between the Z26 pads and the OEM Brembo pads driving my car around on public roads including the spirited driving I do. I do however notice a night and day difference in the brake dust I no longer need to deal with after driving the car 10 miles. |
05-17-2022, 08:11 AM | #53 |
Well, that’s the silliest thing I’ll read today.
05-17-2022, 08:11 AM | #54 | |
05-17-2022, 08:27 AM | #55 | |||
After I wrote what I did, it crossed my mind that the OEM and Z26 pads may have similar friction ratings. In fact, it turns out that the Z26 may have a higher friction rating (more 'grip'). I haven't second sourced this, but one source did indicate that the Z26 pads have a 'GG' friction code, whereas the OEM pads are 'FF'. This code is a DOT requirement for brake pads and the higher the letter in the alphabet, the greater the friction. Quote:
Actually, the OEM Brembo pads are very good, offer a good compromise of friction and rotor wear, and are very resistant to fade. There are a few people on this board who have set lap records using the OEM pads. Of course, different tracks can place different demands on brakes, and there's also personal preference for brake feel. I still run the OEM pads on the tracks I frequent and see no reason to change. Quote:
Not sure if you meant to say "lower"? In any case, I agree that ABS behaviour should be the same, with the caveat that the front and rear pad coefficient of friction must remain the same. If you change that, say by putting a higher friction pad on the front, this will screw up the ABS tuning and result in longer stopping distances. However, this often gets misinterpreted as 'better' because the ABS starts intervening sooner. Nigel |
05-17-2022, 03:57 PM | #56 | |
Matt Miller
2020 SS 1LE |
