02-06-2022, 12:34 PM | #1 |
Drives: A Vette Join Date: Jan 2020
Stock A10 ZL1s 60ft question
Is it difficult getting a stock power A10 ZL1 with just a drag radial in the 1.5 60ft range at the drag strip? I know stock A8 Hellcats have gotten 1.5 60fts with just a drag radial setup but curious to know if stock A10 ZL1s can do that as well or does the " Torque management" restrict them to do so?
What's the best 60fts stock A10 ZL1s are able to achieve with just a drag radial setup on the drag strip? |
02-06-2022, 03:14 PM | #2 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
02-06-2022, 04:43 PM | #3 |
Drives: High HP V8 Join Date: Apr 2020
My Hellcat is bone stock and automatic. I only have 17” MT drag radials and have consistently gotten 1.5 60 foots. Good DA and weather has helped for sure. I’m sure stock A10 ZL1s on a tire can get there as well. Stock A10 ZL1’s seem to average 1.6-1.7 60 foot range from what I’ve seen but I’m sure a lower 60 foot is possible since they are as quick as the Cat in a straight line unless this “TM” holds them back from launching as hard.
02-06-2022, 04:44 PM | #4 |
torque management is the killer with stock TCU settings. Most with perfect traction struggle to get 1.70s with a few high 1.6's noted. The car has the power to do better but the self preservation built into GM's programming is restricting 100% at launch. The tranny also short shifts 1-2 and it is difficult if not impossible to use the paddles to improve.
02-06-2022, 05:01 PM | #5 | |
I've installed a tunable TCM on mine and am working on a 2nd gear launch tune that should produce 60 ft. in the 1.40-1.50 range, based on what I see others running. We'll see in April.
'20 ZL1 1LE A10,
02-07-2022, 10:00 AM | #6 |
First time out at Gainesville, with 17” MT ET’s @ 18psi 2000 DA, ran 1.66 60’. Need to play with pressure, burn out, suspension setting etc. Forgot I had in sport mode not tour, with nannie’s off. Car was heat soaked too, pulling time at top end.
CSP 755 Package. 2” headers, Kong ported blower, NW103mm TB, RF Big Gulp, Mighty Mouse catch can.
630rwhp/660rwtq. |
