02-09-2019, 06:53 PM | #29 |
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged Join Date: Feb 2012
When coming to a full stop , I let the computer do the work of picking when to downshift.
First car I had with the manual mode Automatic , 2007 STS-V, not reading the owners manual , I assumed manual meant I was in control both up and down. Almost ate the steering wheel when slowing and hit the downshift about the same time as the computer, went to 1st gear and about 4500rpm.
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
02-09-2019, 08:26 PM | #30 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Of course, use brakes as needed while downshifting! Dee my earlier post about using a combination of brakes and downshifting. I didn't specifically say that I do both simultaneously, but that's what I meant.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
02-09-2019, 09:52 PM | #31 |
Drives: 17' 2SS Camaro A8 Vert NPP Join Date: May 2017
Like my other post ... keep downshifting to keep the revs around 2.5 - 3.5k; if you need additional stopping force work in the brake pedal as well. Sometimes no brake is needed, especially if you catch a light, or are taking a turn. It's all about feel. Welcome to a tiny tiny taste of race car driving!
02-10-2019, 07:44 AM | #32 |
Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
"Want to slow down fast? Just put it in manual mode and hold the down shift paddle for over a second..."
Yup, did that -ONCE-. Wifey went from zero to BITCH in half a second !!! |
02-10-2019, 09:43 AM | #33 |
Drives: 2016 2LT V6 Garnet Red Join Date: Feb 2017
I only use the manual mode when I want the car in a lower gear when I'm blasting past someone.
For slowing down, it's better to use the brakes than the transmission. Brake pads are cheap and easy to change. |
02-10-2019, 12:23 PM | #34 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Simple illustration - would you want the transmission to already be in a lower gear before entering a tight highway on-ramp . . . or react with a downshift only on the way out of it? Norm
'19 WRX 6M (the family sedan . . . seriously) |
02-10-2019, 05:46 PM | #35 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
For me it depends.
I'd say I manually downshift about 20% of the times I brake and its usually not because of a stop light but an unexpected situation such as someone pulling out right infront of me, merging into my lane or the light literally turns red as Im approaching it and I know I won't clear it and need to stop FAST. Otherwise I just let the transmission do its thing. The Brembo's on these cars are more than strong enough to stop you even in an emergency. The downshifting just adds a bit of efficiency behind it. |
02-11-2019, 04:51 AM | #36 |
Depending how much the brakes are used, mine downshifts by itself; and seems very appropriate to typical traffic conditions.
.......unless the urge to 'cut up" hits you, I don't really think it's a need to worry about most times. |
02-11-2019, 06:12 AM | #37 | |
Drives: 2014 Cyclone mustang Join Date: Feb 2016
Paddles
Paddling has really improved my "auto" experience. I enjoy the twisty's and they are great there. When I light to light, I use them as well. I'm addicted!
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/ |
02-11-2019, 06:40 AM | #38 | |
Though after almost 50 years of owning only MT cars I've found reaching for a +/- gate at the shift lever to be a much more "natural" motion than squeezing at a paddle. Even though it takes more time, or maybe because it does Norm
02-11-2019, 03:15 PM | #39 |
Howdy! Pete here...
Exactly! Shifter > paddles!
PnCRedJwl2SS
