09-13-2021, 11:15 AM | #15 | |
Drives: 2021 Camaro 1SS, 2012 Scion iQ Join Date: Jan 2021
09-13-2021, 12:52 PM | #16 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
I see you're in Virginia, which area because I live in Central Virginia and this is a problem trying to find any type of shop to do this type of work on our cars.
2018 Camaro 1SS 1LE
09-13-2021, 04:44 PM | #17 | |
Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
i've been doing DIY alignments with toe plate twice a year for switching to and from my track tire set. It's been working good until now. My outer tie rods are frozen! |
09-13-2021, 06:59 PM | #18 | |
Drives: 2020 SS 1LE Join Date: Aug 2020
You either need to find a good dealership or a Chevy/race specialist. |
09-13-2021, 08:51 PM | #19 | |
Drives: HBM ZLE Join Date: Aug 2017
09-13-2021, 09:50 PM | #20 | |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
I circled the SS 1LE specs and they didn’t bat an eye and did it. Also had a pit style alignment rack as well. https://my.chevrolet.com/content/dam...supplement.pdf
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
09-13-2021, 10:21 PM | #21 |
Drives: 2019 Camaro 1LE Join Date: Mar 2018
Yes, it drives much better now. Much smoother ride and the steering wheel isn’t tilted to the left when the car is going straight. I haven’t driven it since I brought it home the day of the alignment because the alignment was so bad that the steel wire is already coming through the front passenger tire after 3 months and 2000 miles so getting the tire replaced Thursday.
09-13-2021, 10:31 PM | #22 | |
I may stop by them whenever I’m in Roanoke again since people are saying the alignment is crap still although the driving feel is much better, but I wanted to at least get the alignment better than it was before we head down to Pigeon Forge in a couple weeks. |
09-14-2021, 06:57 AM | #23 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I bet it drives just fine, putting in in spec or "in the green" as I call it, but for a 1LE the performance aspect is where you got shorted.
09-14-2021, 07:47 AM | #24 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Getting an alignment scares me. So many places are so incompetent. You get your vehicle back worse then when you dropped it off. Part of the next service on my SS is an alignment. I will NOT have it done. My tires are not wearing odd, it does not pull, steering wheel is straight... There is zero reason to mess with it. My '07 Tahoe I bought new and traded in '18 I never had aligned once. Tires never wore uneven, it never pulled, steering wheel was always straight. If it isn't broke, don't fix it.
09-14-2021, 10:18 AM | #25 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I set these expectations beforehand but even then sometimes the tech is unwilling to do it properly even if the person at the counter agrees and I have to try another location. A performance shop that has experience doing custom/track/race alignments will likely be more willing to spend the additional time needed to get it right, possibly for a higher price than a standard shop would charge. |
09-14-2021, 11:12 AM | #26 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
There was nothing in your "before" alignment that should have caused a pull. The toe both front and rear was f'd up, which caused the wheel to have to be off center to go straight. But a pull is a force that causes your car to deviate from a straight heading on its own when you let go of the steering wheel. It is not related to whether the steering wheel is centered when the wheels point straight ahead, and it isn't ever caused by toe settings. If your car was really pulling, then the new alignment won't fix it. Camber differential is usually the cause of a pull, but your camber is fine. My guess is your corded front tire has developed a belt shift that's causing the pull, and it won't go away until you replace it.
Matt Miller
2020 SS 1LE |
09-14-2021, 05:45 PM | #27 |
Both before and after front camber numbers are far enough apart to cause a pull IMO.
09-16-2021, 06:39 AM | #28 |
Ive been understanding that +/- camber of a half degree from L to R can/could induce a pull or wander in the steering.
