Old 08-02-2021, 06:10 PM   #15
Rayvan
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic
Originally Posted by 1LEornothing View Post
The plate sounds like a good idea, I don't road course, just friendly Mexico runs and the occasional 1/8th or 1/4 mile event. I was thinking of eventually throwing the factory suitcase back on when the warranty expires so I can throw some catless long tube headers on the car. Truthfully, I removed the suitcase because axlebacks and catbacks are outrageously priced for this car compared to every performance car I have had. A $100 muffler delete and a 35 lbs weight reduction was a no-brainer. For my uses, I have not experienced any adverse effects.
I don't remember if it was here, but there's a guy who runs in the mid nines, Justin Keith, I think. He said that the car lost 3 mph without the muffler in-place. Can't find that thread. May have been another forum.
Some other threads from his forum on this:
https://www.camaro6.com/forums/showt...case+parachute
https://www.camaro6.com/forums/showt...al+effect+aero
Rayvan is offline   Reply With Quote
Old 08-02-2021, 06:26 PM   #16
Village Idiot
Drives: 2019 Camaro SS
If the suitcase prevents drag, would aftermarket mufflers cause more also? Since they typically use the two separate mufflers on each side instead of going across?
Village Idiot is offline   Reply With Quote
Old 08-02-2021, 06:31 PM   #17
LT1ornothing
Drives: 2020 LT1 M6
Another thing is, you 1LE and ZLE guys have much more downforce from the factory. Add to that a "parachute" in the form of a factory muffler delete, and now you exacerbate the downforce+drag dilemma. Us LT1 guys have a much lower drag coefficient and much less downforce, so the parachuting effect of the suitcase delete is less apparent when compared to the 1LE and ZLE trims with all their extra downforce.
Old 08-02-2021, 06:38 PM   #18
LT1ornothing
Drives: 2020 LT1 M6
Yes, I would imagine so, and the more downforce of the trim you own, the more the the suitcase delete slows you.
Old 09-17-2021, 06:02 PM   #19
wheelspeed
Drives: Ford Flex
I don't understand this suitcase thing... How could you not be able to just bend up a sheet of tin to negate any effects of the shape of the 'suitcase' having been removed?
I mean, good comments that people shared so that others are aware, but most comments were spoken like it was an insurmountable problem of removing the suitcase and you just had to put it back on. It doesn't seem like it'd be hard to fix any aero problems of removing the suitcase.
wheelspeed is offline   Reply With Quote
Old 09-20-2021, 05:49 PM   #20
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
just got my car corner balanced and weighed over the weekend 3623lbs with 3/4 tank of gas
Old 09-20-2021, 06:36 PM   #21
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
Thanks for posting, pretty big correction.
khcoaching is online now   Reply With Quote
Old 09-20-2021, 06:43 PM   #22
kropscamaro16
yup pretty crazy i thought it would be lighter than that but oh well next goal is to get it under 3600 but its still a PIG lol
Old 09-20-2021, 07:10 PM   #23
Village Idiot
What all do you have removed? I’d really like to get mine mid 3,500lb but I don’t want to lose too many creature comforts.
Old 09-20-2021, 08:14 PM   #24
khcoaching
khcoaching's Avatar
Mid 3500s would be fantastic and I think a reasonable goal.
Ken
Old 09-21-2021, 10:33 AM   #25
kropscamaro16
aftermarket seat lightweight battery lighter wheels full spl parts suspension kit aftermarket coilovers rear seat delete etc...
Old 09-27-2021, 01:30 PM   #26
DeltaEliteMan
DeltaEliteMan's Avatar
Drives: 2018 ZL1 Nightfall Grey Vert
(Even though this would not be cost effective for the weight you'd save)
If money were no object, would it be possible to replace the larger suspension bolts with titanium bolts & nuts?
If so, would there be any issues with using titanium bolts in this application (i.e. loosening, dis-similar metals touching causing corrosion, pre-mature wear)?
*I wonder how much weight would be saved if ALL bolts and nuts on the car were replaced with titanium?
DeltaEliteMan is offline   Reply With Quote
Old 09-27-2021, 01:40 PM   #27
kropscamaro16
i heard spl parts actually uses titanium bolts in their kits so maybe some of my parts already have them haha
i know ive seen the lugnuts and they are superlight but $$$
https://zl1addons.com/products/lug-nuts-titanium
Old 09-27-2021, 06:55 PM   #28
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Katech lug nuts are cheaper and work well (I have used them 2 years). Like holding potato chip's, they are really light...
Timbo-1LE is offline   Reply With Quote
