04-30-2019, 08:09 AM | #1 |
Great White
Advantages to square setup?
Hi all,
What are the pros or cons to having a square tire/rim setup as opposed to a staggered setup. I already know about the rotation of tire advantage with a square setup but other than that. If the car came with staggered will anything be affected by a square setup? Any thoughts on pros or cons would be appreciated.
04-30-2019, 10:27 AM | #2 |
Drives: 2014 Camaro SS Join Date: Jan 2019
Staggered is objectively better looking and more of an iconic muscle car look. Square will put more tire on the pavement since you’re not running a skinnier tire on the front. More tire on the pavement equates to better grip when carving corners. If that’s not your thing, just stick with staggered.
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
04-30-2019, 10:40 AM | #3 |
Great White
Yeah..I like the staggered look. I'm not into tracking so if rotation is the only clear pro for square I think I'll stick with staggered. THanks.
04-30-2019, 10:41 AM | #4 |
Aside from what you mentioned...
Theoretically: -Less understeer / more front end grip -Potentially less front responsiveness (really depends on the tire, but it will feel different) -Change in chassis dynamics I'm in it for more grip. 305/30-19 squar, will go bigger square when I sort out the best way. You can tune some of the chassis behavior with suspension tweaks (height, compression/rebound, spring rate, adjustable / different size antisway bars) Mine was square to begin with, 285's on the 1LE, but with more stretch in the rear so not exactly square behavior. IMO if you're a corner carver / road course person - these cars really need as much tire as you can fit. 325's would be nice all around
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
04-30-2019, 11:20 AM | #5 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Under braking, you're demanding a lot more from the front tires than from the rear tires, so if your driving includes a lot of really heavy braking from high speeds, you'll want more front tire rather than less. When you put a front-heavy car into a corner, the front tires are carrying more than half of the car weight. Plus they're the tires that actually get the turning started. Once again, you're demanding more from the front tires. It's only during acceleration that you start needing more rear tire than front tire. In more powerful cars - perhaps "torquier" would be better - this can start well before you've got the car straightened out in a turn. A little extra cushion against power-driven oversteer is your friend, and it's arguably better to get this by making the rear tires wider than the front tires narrower. Since the original muscle cars were only good at straight line acceleration and marginal at best about the other two, and because most people are more familiar with them than with cars built for road-racing, that's where popularity of staggered arrangements comes from. Most people are still influenced more by drag racing, and running hard in straight lines still is the first aspect of performance driving that people come to understand or get any good at. No flame intended, but from a hard-core corner-carving point of view a "square" or "almost square" arrangement can actually be the better-looking because it promises to be better at a wider variety of driving situations. Maybe there's a bit of "insider knowledge" going on as well - you know it's been done that way because there was more than just one performance reason in mind. Norm
'19 WRX 6M (the family sedan . . . seriously) |
04-30-2019, 05:18 PM | #6 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
I went with a square set-up, but if you are in it for looks, go staggered IMO. I wanted more rubber on the ground.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
04-30-2019, 06:51 PM | #7 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
A square set up is best for handling curves at high speeds, like in auto crossing, road and track racing and mountain roads. The staggered set up is best for straight line, drag racing .. and it looks better.
05-01-2019, 05:31 AM | #8 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
and along with the things the others have already mentioned....a squared set-up allow you to rotate the tires to even out tire ware.....where as in a staggered set-up you can't and you will typically ware the rears at about a 2 to 1 ratio (you will buy/use 2 sets of rears to every 1 set of fronts).
05-01-2019, 08:06 AM | #9 | |
Great White
05-02-2019, 07:24 AM | #10 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
My wheels are a square set of 20 x 10 but I staggered the tire sizes. I just like the look of the wider tires in the rear
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
05-02-2019, 07:31 AM | #11 |
376 cubic inches of fun
For 99% of us, the only benefit of stagger is the looks.
Unless you track the car or drive foolishly on public roads, you won't know the difference. So it would seem that the square setup is more practical due to rotation. I have too say though, that I never rotated my OEM P-Zeros, and got almost no feathering on the fronts over the life of the tires. |
05-02-2019, 08:04 AM | #12 | |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
05-08-2019, 12:38 PM | #13 |
do you road trip a lot? Going square allows you to carry a spare that will be worry free on all 4 corners
05-08-2019, 03:03 PM | #14 | |
Drives: 2014 2-SSRS Slushbox Join Date: Sep 2018
Stalker, any pics of your square setup? My rims are 20X10s all around. Square sounds nice now. |
