01-04-2019, 07:46 AM | #15 | |
I pretty much want the power when needed. Once in a while, some buddies of mine and I go to this track in Nevada and have a little fun. Its a road course track. Tires, I am running Michelin PS4 285 30 R20 in the front and 305 30 R20 in the Rear. If I went ProCharge, I was thinking the P1X system with the stage 2 Intercooler. I have a Tuner in Calif that will do all the Tuning and Dyno for me.
2016 Camaro 2SS "Black Widow" |
01-04-2019, 09:39 AM | #16 |
You could go either really...with a Centri, I would opt for a higher stall converter. Both the Magnuson 2300 or Whipple 2.9 will do well as they both are easily 9 second capable superchargers. The Exorcist ZL1 uses a Whipple and has been 147mph in the 1/4. The Maggie has been 145 on a built SS, so both very close...go with whatever unit you can get the better price on and put the savings toward fuel system upgrades.
2016 NFG 1SS A8
01-04-2019, 11:14 AM | #17 |
Drives: SS 6 speed of course Join Date: Jan 2016
instant power would be a PD, it will not be faster street, autoX or road race, but the power is more instant. I would not run more than 6 PSI on a road race or autoX till you get forged pistons or at least increase the ring gap in the stock piston.
Also I want to clarify "instant power", the Centri is moving air at RPM, so it is NOT a turbo that is exhaust flow dependent. Put it this way 1st gear you floor it, the Centri is moving air as if it were already in WOT conditions, that air is being bled off by the BOV, the BOV will close quickly ( fractions of a second) and the "boost" will be entering the TB / intake manifold. With my HUGE pulley (low boost) it is .25 to .5 seconds before my boost gauge sees the 2 or 3 PSI of boost and the tires are breaking away. This is the ONLY condition where one can feel there is not "instant power". For instance, shifting 1st to 2nd the Centri is putting out more boost and power than the street tires can hook to the ground. So yes a PD will at a certain RPM say 3500 RPM in gear offer some slight (fractions of a second) boost / power over a Centri, after which , on street tire, it can't hook and you are feathering the throttle. WOT is not usable on my 4.5 pulley (ultra low and slow boost) D1x till into 3rd gear street tire, clear dry road. I have PS4s. A 4.0 or 3.75 pulley is going to be moving much more air much sooner. With my E85 tune (as soon as lingenfelter will ship me the pump due LAST YEAR). I would anticipate even more need to be careful with the the throttle at an legal speed.
01-07-2019, 10:52 PM | #18 | |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Looking forward to a d1 in the top 10.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
01-08-2019, 10:41 AM | #19 |
Drives: 2016 2SS Join Date: Jul 2016
I have been 9.70's with a P1X in a full weight 2SS in +2,500 DA. So they work.
01-08-2019, 12:13 PM | #20 |
Drives: C5 Join Date: Nov 2018
If you plan on doing ANY track work, PD will not work.
They heatsoak like crazy and you will be able to 3-4 hard laps. Centri will come on later and doesn't have this crazy tq off the bottom, but it's also better for coming out of corners and easier to manage wheel spin. No heat soak and install is much easier and allows to use better intakes if needed. |
01-08-2019, 12:48 PM | #21 |
Not me, I would have ordered an auto if I was going to 1/4 mile the car. My car is and lives in the wild (aka the backroads of Texas). Lots of active wildlife out here like Hellcats and Mustangs... Sure I hear all the time about the xyz 10 second car. All I can say is in the wild my Camaro has eaten everything it has found, so I 'm not worried about some cage entertainment that can do a 1/4 at a time...
01-08-2019, 01:13 PM | #22 |
Here is the fast list:
1 and 2 are Procharger 3,4,5 are maggie 6 is a TT 7 is a maggie 8,9,10 are Prohargers so that would mean 50% of the fast cars are Procharger including the two fastest. The fastest street tire bolt on is a 10.805 that is NO2 BTW The fastest and quickest blown car on street tire is actually a M6! Jhunsberger 10.871@129 MPH that is a whipple. Some stone stock ZL1 are real close to this on street tire (10.943 @ 128.3 MPH). The conclusion would be that for street tire, it is HARD to be an A10 LT4 stone stock. That DR are needed to do better, which my own traction issues would indicate.
01-08-2019, 01:38 PM | #23 |
I figured there would be some whipples, but they are further back. The P/D prochargers series are more like the Maggies and F prochargers are in their own zip code at this time. Hopefully we will have some 2650's this year that are competitive with the two front runners. Our white car has been 9.15@154 but Mike has never posted the time slip and that was launching in 2nd gear, never could hook the car in low.
01-08-2019, 06:04 PM | #24 | |
2016 NFG 1SS A8
01-08-2019, 06:34 PM | #25 |
Drives: Camaro Join Date: Sep 2018
If you run a 9.99 e.t. or faster plan on adding a roll bar & using SFI parts.
01-08-2019, 07:21 PM | #26 |
Drives: 2018 ZL1 Join Date: Oct 2011
That’s amazing!!
2018 ZL1…Many mods to come
01-08-2019, 09:56 PM | #27 |
Oldman only listed the SS so I hadn't looked at the Zl1 list. Great pass for sure but didn't see that on the Zl1 fast list either. He should post it.
01-08-2019, 10:39 PM | #28 | |
That is clearly fallacious since all of the top times you mentioned were either Maggies or F1's. Pray may have one to add and same with Mike. But, going off what has been posted...my point is that your statement is completely wrong. Now, I have owned multiple Prochargers so this was in no way a rip on the Procharger. But I really, really hate it when people with absolutely no real standing make statements like that. Prochargers work, no doubt about it. But if you are comparing base kit to base kit running let's say under 600whp. Good luck with that. I know because I was getting smashed with my P1 all day long by mustang guys running the PD blowers. I eventually got things worked out so I could be really competitive. . .but to act like the PD blowers are never faster...well, like I said, the Fast list speaks for itself. In my opinion, taking a F1 blower running NOS is NOT the comparison anyone here was talking about. But when you say, "1 and 2 are Prochargers" please be honest and admit they are F1's running NOS. Which isn’t even close to an apples to apples comparison. In the top 5 what You just said: 2 F1’s and 3 Maggie’s. That is my point. Mic dropped...good day.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 01-08-2019 at 11:09 PM. |
