08-29-2019, 09:29 PM | #1 |
errrr cant get BMR delrin bushings to line up.
they are in the cradle fine. i can get the front lined up but i can not get both the rear bolts in. i can move the whole cradle as long as the front bolts are not tight enough for the alignment pins to be in. but i can not get the rear bolts in even with the front alignment pins in. worked on this all day. errrrrrrr
08-29-2019, 10:37 PM | #2 |
i have a idea. rear in 1st with bolts through the bushings. strt rears in maybe an inch then wiggle it on the front alignment pins.
i was also thinking of studs.
09-01-2019, 12:16 PM | #3 |
Drives: gas powered Join Date: Jan 2019
Any chance the front bushing and rears are swaped somehow?
09-01-2019, 12:27 PM | #4 |
no. the fronts have a groove and partially drilled out bigger for the alignment pins. i noticed the oem bushings have a huge hole in them for the bolt and the bmr are only big enough for the bolts.
09-06-2019, 09:04 PM | #5 |
i ended up using 150mm studs.
09-06-2019, 10:00 PM | #6 |
i torqued the studs too 100lbft with blue medium threadlocker. the original bolts are 74lbft + 105deg
09-11-2019, 04:49 PM | #7 |
Drives: 1LE Join Date: Sep 2017
09-11-2019, 04:50 PM | #8 |
OH your not talking about their sway bars...
09-11-2019, 05:46 PM | #9 |
I have there adjustable bars
10-14-2019, 07:25 PM | #10 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
How's the ride (NVH) with those delrin bushings?
Would it be tolerable for a DD in your opinion? Also, would like to know how much improvement with the sway bars?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
10-15-2019, 02:04 AM | #11 |
i noticed no NVH. i would have no problem putting them in a DD. The sway bars were a slight improvement over the 1LE bars. I probably wouldn't bother with the bars unless it was used on the track.
