09-01-2016, 11:43 AM | #1 |
Drives: 2016 SS Red Hot Join Date: Mar 2016
Rear Tow Hook?
Am I the only one who is a little dismayed by the fact that the gen 6 Camaro has no place to put a rear tow hook? Has anyone had to tow/recover their 6th gen Camaro from the rear? Where on the car did you hook on to? Does anyone have any aftermarket goodies to help with this process? Thank you wise and generous forum gurus.
09-01-2016, 07:12 PM | #2 |
Drives: 2016 Camaro SS Join Date: Apr 2015
If I remember correctly, you can not tow with the Camaro at all. The engineers say its a big no no.
Hyper Blue 2SS Auto, Duel Mode Exhaust, MCR, Nav, Black 5 Spoke
Ordered on 8/29 2000 Status on 9/1 3000 Status on 9/3 3300 Status on 10/8 3400 Status on 10/9 3800 Status on 10/19 Delivery 12/28 |
09-01-2016, 07:28 PM | #3 |
Drives: 2010 CobaltSSTC Join Date: Sep 2015
So no towing a tiny trailer of track rims/tires? Or a small seadoo? that's a bummer.
09-01-2016, 07:31 PM | #4 | |
Drives: 2014 2SS/RS 1LE Join Date: May 2013
09-02-2016, 03:33 AM | #5 |
Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
Is the factory provided tow-hook on the front not to your liking? You can see mine in yellow in the front grill of my SS...
09-02-2016, 10:50 AM | #6 |
I am not interested in towing anything with my camaro and I love the factory front tow hook option. My question is: what if I come around turn 2 on my local track and find myself nose-first into a hay bale. How do I hook a recovery strap to the back of the beloved camaro and pull it back to safety? Any thoughts?
01-03-2017, 11:14 AM | #7 |
Does anyone have any suggestions on how to hook a recovery/tow strap to the rear of a Camaro?
01-03-2017, 03:46 PM | #8 |
Drives: 2016 SS Join Date: Jun 2011
I don't think anyone has a good answer for you. I've been looking at underside pictures and exhaust install videos and I'm not seeing anywhere you could even get a strap without damaging something else. Definitely can't see a good, easy place for a tow hook.
If you really HAD to have one you would probably need to remove the rear plastic bumper cover, find a good place to mount a hook, and then cut the bumper cover to allow it through.
01-03-2017, 03:46 PM | #9 | |
Drives: 2016 Z06 coupe Join Date: Dec 2016
01-03-2017, 03:50 PM | #10 |
Well if you're going to do that, just open the trunk, loop a tow strap around the latch area, then slam the trunk on it.
01-03-2017, 04:58 PM | #11 |
The one from ZL1 Addons for my 5th Gen had to drill a hole in the bodywork behind the license plate for install. I can remove the license plate and put the hook in and then remove and replace the license plate when done. I would check with them to see if they have something similar for the 6th Gen.
01-03-2017, 08:12 PM | #12 | |
Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
01-03-2017, 08:39 PM | #13 |
Drives: 2017 A10 ZL1 Join Date: Apr 2013
On my 5th gen race car we custom fabbed a tow strap through the exhaust hole in the diffuser to the body. I don't have a 6th gen to look at and see if its possible but its definitely something to think about.
01-03-2017, 10:24 PM | #14 |
Drives: 16 2SS NPP MRC Join Date: Aug 2016
I am fully planning on towing with my camaro but that's a secret and not something you guys are allowed to share. As for the op you could install the curt class 2 accessory hitch. Pretty confident that would suffice in a recovery situation, has a 110 lbs weight rating as well and is sold on gm accessories on the gm website. My life is towing and there's a few tricks up my sleeve!
